Question about Casio Brand New-Fx-991es Plus - Scientific Calculator
1MOD33 PLEAS ANY ONE CAN TELL ME HOW TO CALCULATE 88^5 MOD 87
A mod B in Casio fx-115MS How to get an m mod n (ie to calculate modulo of a number)
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate m mod n, calculate m-m/n*n. No shortcuts, no rearranging. That's m minus m divided by n times n. You have to enter both numbers twice, but you will get the modulus.
Press MODE 1 to return to your previously scheduled calculations.
May 30, 2011 | Casio FX-115MS Plus Calculator
I need to calcualte 4587 mod 8 how do i do this on the casio fx-115MS? (there's no 'mod' button) Many thanks
The lack of a mod function makes this more than a bit painful. Here's one way:
Press MODE 4 to go into BASE-N (integer) mode. If the display doesn't read "Dec", press the x^2 key. Now calculate 4587-4587/8*8 (press 4 5 8 7 - 4 5 8 7 / 8 * 8 =, where * is the multiply and / is the divide).
You can calculate other mod problems the same way. a mod b is a-a/b*b.
May 11, 2011 | Casio FX-115MS Plus Calculator
I need a fuse box layout for my 87 ramcharger can any one tell me where to find one? I have lost my owners book.
most all part stores have chiltons repair manuals.the one you will need is.CHRYSLER full-size trucks 1967-88 repair manual book# 20400. it has everything you will need. the 87 fuse box layout is in there they cost around $25.00 its a great investment. hope i could help. THANKS. MIKE
Feb 20, 2011 | 1987 Dodge Ramcharger
Where to find the mod function on ti 89. So I can calculate 14mod 15.
It's in the MATH NUMBER menu. To calculate 14 mod 15, press
2ND [MATH] 1 9 1 4 , 1 5 ) ENTER
Jan 24, 2011 | Texas Instruments Office Equipment &...
How to calculate modulus
This calculator does not support the modulus operation directly, you have to simulate by a divide followed by a subtraction and a multiplication. Suppose you want to calculate 256 mod 17:
  1. Key in 256 [÷] 17 [=] and get the result 15,0588...
  2. Note the 15 in front of the decimal separator and key in [−] 15 [=]
  3. Get the modulus: [×] 17 [=], result should be 1.
Jan 14, 2011 | Casio FX82MS Scientific Calculator
How to calculate mod or modulus
This calculator does not support this operation directly, you have to simulate by a divide followed by a subtraction and a multiplication. Suppose you want to calculate 256 mod 17:
  3. Get the modulus: [×] 17 [=] and get the modulus, 1.
Jan 12, 2011 | Casio FX991MS Scientific Calculator
Please tell me how to find out the mod like 2%100
The fx-115ES does not have a modulo operator. However, it is possible to compute the remainder using integer arithmetic. Press MODE 4 to shift into integer mode. Then calculate A modulo B as
A - B * (A / B). For example, to calculate 2 modulo 100, press
2 - 1 0 0 * ( 2/ 1 0 0 ) =
and get 2.
Press MODE 1 to return to real arithmetic.
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
Gear shift lever sheared off . I can't find the part in the salvage yards, is the '88 compatible? What do I need to do to replace the '87 with the '88?
If you go to AutoZone, they can pull up a part number for the shift lever of each year and see if they match. You could even call them to do this over the phone. If it's not a match, they may be able to tell what the difference is with photos on the computer and tell you if it will work. Good Luck.
Dec 09, 2009 | 1987 Dodge Colt Vista Wagon
M mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Jun 29, 2009 | Casio FX-115MS Plus Calculator
Driving home my truck quit running
well you didn't specify the year, make, and model of the truck you are asking about so this is the best answer I can come up with. Below is a list I found that says what vehicles are interference motors...
INTERFERENCE ENGINES WITH TIMING BELTS
ACURA
1986-89 1.6L Integra
1991-95 1.7L Integra
1990-95 1.8L Integra
1986-89 2.5L Legend
1992-94 2.5L Vigor
1986-89 2.7L Legend
1990 2.7L Legend
1991-95 3.0L NSX
1991-95 3.2L Legend
AUDI
1970-93 All Except 1970-77
1.9L & 1970-73 1.8L
BMW
1987-95 2.5L 325I 525I
1994-95 4.0L 740I
CHRYSLER
1993-95 1.5L Colt
1987-88 1.5L Colt
1992-95 1.5L Eagle Summit
1987-88 1.6L Colt
1989-92 1.6L Eagle Summit
1994-98 2.0L Neon Stratus
1990-95 2.0L Eagle Talon
DAIHATSU
1988-92 1.0L Charade
1988-92 1.3L Charade
1990-92 1.6L Rocky
FIAT
1974-79 1.3L 128 Series
1979-82 1.5L Stranda
1974-78 1.6L 124 Series
1974-78 1.8L 124 Series
1974-78 1.8L 131 Series, Brava
1979-82 2.0L Brava, Spider
FORD
1981-85 1.6L Escort, EXP
1981-83 1.6L LN7, Lynx
1984-85 2.0L Escort, Tempo
1993-95 2.0L Probe
1986-88 2.0L Ranger
1984-87 2.0L Lynx, Topaz Diesel
1985 2.2L Ranger
1989-92 2.2L Probe
1986-88 2.3L Ranger
1986-87 2.3L Diesel Ranger
1991-98 4.6L Crown Victoria
GM
1986-95 1.0L Geo Metro
1989-91 1.0L Firefly (CANADA)
1985-88 1.5L Sunburst (CANADA)
1985-89 1.5L Spectrum
1990-93 1.6L Prizm, Storm
1981-84 1.8L Diesel (CANADA)
1982-86 1.8L Buick Skyhawk
1990-98 1.9L Saturn
1987-88 2.0L Buick Skyhawk
1988-95 2.3L Quad Four
1985-87 3.0L Buick
1979-95 3.8L Buick
HONDA
1986-87 1.0L Prelude
1973-78 1.2L All
1973-78 1.3L All
1980-84 1.3L All
1973-78 1.5L All
1985-89 1.5L Civic
1988-95 1.5L Civic, CRX
1993-95 1.5L Civic Del Sol
1979-84 1.5L All
1985-87 1.5L CRX
1993-95 1.6L Civic Del Sol
1973-78 1.6L All
1980-82 1.6L All
1988-95 1.6L Civic, CRX
1984-87 1.8L Prelude, Accord
1979-83 1.8L All
1986-91 2.0L Prelude
1990-91 2.1L Prelude
1990-95 2.2L Prelude, Accord
1992-95 2.2L Prelude
1995 2.7L Accord
HYUNDAI
1984-95 1.5L Excel Scoupe
1995-98 1.5L Accent
1992-95 1.6L Elantra
1993-95 1.8L Elantra
1992-95 2.0L Sonata
1989-91 2.4L Sonata
1990-95 3.0L Sonata
INFINITI
1990-92 3.0L M30
ISUZU
1987-89 1.5L I-Mark
1990-93 1.6L Stylus Impulse
1987-89 2.0L Impulse
1981-87 2.2L Diesel Truck
1986-95 2.3L Truck Trooper
1988-95 2.6L Truck Rodeo Amigo
1991-96 3.2L Trooper Rodeo Amigo
KIA
1995 2.0L Sportage
MAZDA
1984-85 2.0L 626
1988-92 2.2L 626 MX6
1989-93 2.2L Pickup
1988-95 3.0L 929 MPV
MITSUBISHI
1985-95 1.5L Mirage Precise
1990-92 1.6L Mirage
1989-95 2.0L Galant Eclipse
1983-86 2.3L Diesel Pickup
1994-95 2.4L Galant
NISSAN
1982 1.5L Centra
1983-88 1.6L Sentra Pulsar
1987-89 1.8L Pulsar
1982-89 2.0L Stanza 300ZX
1984-95 3.0L Maxima 300ZX Pathfinder
PORSCHE
1976-83 2.0L 924
1976-89 2.5L 944 Series
1989 2.7L 944 Series
1989-91 3.0L 944 Series
1976-83 4.5L 928
1984 4.7L 928
1985-91 5.0L 928
1992-95 5.4L 928
SUZUKI
1985-94 1.3L Samurai Sidekick
1989-94 1.3L Swift
TOYOTA
1986-95 1.5L Tercel
1981-83 2.2L Pickup
1984-87 2.4L Pickup
1982-88 2.8L Celica Cressida
1987-94 3.0L 4-Runner
VOLKSWAGEN
1976-91 All Except 1.9 2.1L Engine
1990-92 1.6L Golf (CANADA) Jetta
1990-95 2.0L GTI Jetta GLI Passat
VOLVO
1991 2.3L Coupe 940
1986-94 2.3L 240 740 940
Jan 30, 2009 | 1994 Nissan Maxima
Casio Brand New-Fx-991es Plus - Scientific Calculator Logo
23 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
