Question about Bosch Washer Style Wfmc5301uc And Electric Dryer Set
WFMC5301UC/16 SHOWING E13 ERROR CODE
WHEN GOES TO DRAIN THE WATER OUT JUST FLASHES THE ERROR CODE
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Washing machine has stopped w/ water still in drum
Hello and welcome to fixya.
The "E13" error code on the WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
You haven`t mentioned if you`ve checked the pump...just hoses as you did mention.
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.
  6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
  7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
  8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
Posted on Jul 08, 2010
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
I keep getting E22 warning
E22 is residual water in sump, this could be blocked pump, dirty filter, grease build up. If you have removed white pump cover to check for blockages, ensure that it is completely clipped back into position before trying again. The non return valve maybe allowing dirty water to drain back into the machine. If you tend to run a quick wash a lot, you may need to boil a kettle and pour it into the sump to clear any build up from around the optical sensor in the sump. Post if you need further assistance
Feb 17, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My Bosch front loading washer is flashing E:13 and won't open
Hi, i had an E-13 error code on my Bosch 500 series washer. The drain pump impeller was plugged. Access the drain impeller at the bottom front right corner. Just put a pen in the hole and turn the cover. Then you need to manually drain the washer. I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while. When you get it drained you can take the cap completely off. When I did I found a wipe in the impeller. I took it out and put it back together and the washer worked just as before.
Take care
Jun 13, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
My washer is flashing E:13; locked with wet clothes inside
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
macmarkus :)
Washer not draining and rinsing
Hello Wet Towels, well to be honest outside of the test program I have never seen a fault code E13. If it was an error E03 I would check my water to make sure it was turned on, the cold inlet hose wasn't pinched, or debre filling the filter screens in the hose or water valve. That is what the care and use says about E03. In the back of your owners manual it tells you what the fault means and how to correct it. If this doesn't work call for service to resolve your issue. Hope this helps.
Aug 10, 2008 | Washing Machines
Bosch Washer Style Wfmc5301uc And Electric Dryer Set Logo
44 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
