Logitech K260 keyboard - Left shift key sticks - Only had couple of weeks (not abused or anything spilled on it)
Left shift key does not work all the time
SOURCE: keyboard problems - crtl, shift, alt keys does not work
I met the same problem, and I fixed it.
For my own case, it is mainly a hardware malfunction happening at the data bus(the wide, plastic strand) connecting the keyboard to the mainboard.
I found that part of that strand was bent, so I squeezed it to keep it flat.
everything has been OK since I did that.
zhao qi
Posted on Jul 03, 2008
  • 25 Answers
SOURCE: logitech cordless desktop mx 3200 laser keyboard - french characters
Its not the keyboard fault but your operating system. I'm going to assume you live in Canada and when you had setup the computer for the first time you had selected Canada has country you live in instead of the United States (default) If you notice on your desktop or taskbar there will be a keyboard logo. Click it and select US 101 keyboard (United states). You get the french symbols because microsoft thinks because you live in Canada you must be french canadian.... stupid eh! They have it selected to mulitlingual Canadian. Select the US English as default and you shouldn't get those french symbols when you really want the shift or question mark key.
I live in Canada and I see looks of people who ask me the same question all the time.
Hope this helps!
Posted on Aug 21, 2008
  • 64 Answers
SOURCE: F Keys aren't working, nor Alt-F4
Do you have an F-Lock button on your keyboard? Most of the time that is the culprit of this problem.
Posted on Jul 17, 2009
SOURCE: wireless keyboard no power
twilight28 is a ridiculous fool. Firstly, "Apple doesnt work" in a nonsensical statement with a punctuation error. Secondly, if I am to infer Twitlight28's meaning then an entire company of products do not work ... Wow! Additionally, how was that supposed to help anyone? Finally, who cares about your stupid brand loyalty, it is all a matter of personal taste
Posted on Dec 14, 2009
  • 611 Answers
SOURCE: Gateway Keyboard left shift key adds a pipe character
The driver will not fix the problem, as this is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://lotus.kick-***.net/keyboard
Here are the instructions without the pictures:
I had a problem with my Gateway keyboard where whenver I pressed the left shift key, it type a pipe | (verticle line) character. This is the same character that is above the back slash character . I searched the internet and people were suggesting reloading drivers and apparently Gateway was suggesting a destructive reload of the hard drive. That's absolutely rediculous.
After some research, I determined that on some European style keyboards, the backslash/pipe key is between the left shift and the "Z" key. So, I removed the left shift key to experiment. The key simply pops off by sticking a screwdriver under it. (It is not necessary for you to do this).
When I used a little screwdriver to press on the center of the plastic (red arrow) I would get a proper shift key. However, when I pressed to the right (green arrow), I would get the backslash character. If I pushed at the red and green arrow together, I would get the pipe character.
Ah-hah! I determined the problem. The inside of the keyboard is a "universal" type and can be used with U.S. or Europeon keyboard layouts. For whatever reason, the left shift key was hitting both dots under the key. (The dots are visible in the pictures below.)
To resolve the problem, it is necessary to disassemble the keyboard. On the bottom of the keyboard is a bunch of screws. Remove all of the screws. If you have any rubber feet, there is probably screws under the rubber feet. The feet are just held on by sticky taope, so they peel right off.
Once all of the screws are removed the top and bottom halves seperate easily. The circuits stay in the bottom half of the keyboard, so set the top half of the keyboard to the side. The red arrow marks where the left shift key presses down.
Pull back the top layer and you will see the flexible circuits. These are also made up of multiple layers. When a key is pressed it pushes these layers together to complete the switch circuit. The red arrow marks the shift key. The green arrow marks the backslahs/pipe key for European style keyboards. The blue arrow is yet another key that is not used on U.S. keyboards.
Pull back the first layer of the switch circuit to expose the space between the circuit layers.
Place a small piece of electrical tape on the extra backslash/pipe circuit connection as marked by the red arrow.
Now simply reassemble the keyboard and that weird pipe character will never accidentally show up again.
Posted on Jun 19, 2010
HOW TO GET MY LAPTOP TO STOP USING THE PINK ALTCAR
I found this on another website and it worked for me. Good luck.
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
Sep 25, 2010 | Sony VAIO VGP-WKB1 Keyboard
How to use Alt Car key?
I am guessing the Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. On these models, it seems the alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Aug 13, 2010 | Sony VAIO VGN-FS640W Notebook
SHIFT KEYS NOT WORKING PROPERLY
Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 27, 2010 | Acer TravelMate 2480 Notebook
Keyboard keys share functions. Right shift key inserts a z and then shifts. z key does the same thing . Left shift key tabs and then shifts. 9 key and = key both give =9. Other keys also share...
1. try to do system restore first from the time system was working fine. reboot system. if fails.
2. update your anti virus then run a full system scan. reboot system. if fails.
3. update the bios. download the latest bios for your system from the dell support drivers and download section. reboot system. if fails.
4. reseat the keyboard cable. if fails.
5. reinstall the OS. if fails
6. replace keyboard.
Oct 25, 2009 | Dell Inspiron 2200 Notebook
Left shift + T, right shift + E doesn't work on an hiper keyboard
Your shift key is broken, if this product was recently purchased, return it for another. If you've had it for a while and it just decided to stop working, your best bet would be to pry the Left Shift key off and clean around that area and properly attach the key back on - its possible it wasn't hitting the sensor when it was pushed down.
If this does not fix your problem please leave a comment and I will assist you further.
Jul 17, 2009 | Microsoft K5100141 Keyboard
Shift Keys not working properly on ACER notebook
The 8042 keyboard controller has been integrated into one chip with other I/O functions so I doubt you can replace it as a single IC and I'm afraid that is what has failed. It is an extremely rare failure but I guess it has to happen some time. The keyboard is kind of a polled matrix so it only takes the failure of a single line to bollix things up.
I think what you are talking about here is a motherboard exchange or repair.
Dec 13, 2008 | Acer NSK8458AN Keyboard
Problems with the keyboard
Sticky keys can sometimes be fixed by hitting right shift key 10 times quickly (I'm not lying!!), and or the culprit key (x) the same way. Try that and if it doesn't work, reboot and type. If it continues, please try another keyboard.
Nov 20, 2008 | Computers & Internet
Compaq laptop can't get the ? symbol
Looks like the French keyboard mapping is still in effect.
You can try changing the keyboard keys back to where they were by pressing:
Left CTRl + left Shift at the same time. then try typing the ?/ key. You may have to try this a couple of times to get it to work.
If it does work, try the right ctrl/left shift key.
Also found this:
Control Panel, Regional and Language Options, Keyboards and Languages,
Change Keyboards. Select the keyboard you that's causing you grief and
choose Remove.
If you don't remove the keyboard map, when this switch happens, you'll have
to exit the application you're in (Outlook, for example), change keyboards,
and restart the app. Changing keyboards without restarting the app doesn't
seem to change the mapping.
Hope this helps!
Sep 06, 2008 | Computers & Internet
Shift question mark not working
Keyboards can go bad - luckilly they are cheap. It may be time to replace it.
Jul 18, 2008 | Televison & Video
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
