Question about Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder
Zoom is stuck and reset button not working.
My zoom control is stuck where it is zoomed always and the reset button doesn't solve the problem. Please help. I just bought this 6 months ago and have used it only a couple of times. Thank you!!
  • 169 Answers
One of the two motor of the lens of your camera is stuck up that why push reset is alway appearing and the power is blinking....only a technician can fix your problem....
Posted on Sep 09, 2007
SOURCE:
My apex tv is stuck on zoom, how do i fix it?
Hello
Make a factory reset to this set. I assumes that you have its remote control wih you now, and posts this solution. If you did forget the parential pass code, just enter '6688' when the set asks for passcode. The previous set passcode will clear out, you ahve to set a new passocde in place. After resettign the pascode, just make a factory reset to the set, by entering into it menu option.
Without remote control, you can't do anything with this set. If you lost its remote control, you can buy it directly from Apex Digital. The price ofr the remote control in US or Canda is $35. In this case, please contact
APEX DIGITAL,INC,
Customer service: 2119E, Philadelphia, Ontario, CA91761
866-4APEXINC.
website: www.apexdigitalinc.com
OK
Dec 01, 2011 | Apex Digital GT2015DV 20 in. TV/DVD Combo
The tv picture is stuck on zoom and we are loosing part of the picture. How do you turn the zoom off?
Howdy, this is usually controlled by the button marked ASPECT RATIO. pushing this several times will usually solve that issue.
farmerbear at FixYa.com
Sep 15, 2010 | Televison & Video
The zoom button is not working properly. When you go to zoom in or out it goes all the way out or zooms all the way in. PLEASE HELP
thats just because your zoom leaver is stuck. all you have to do is when your zooming and it keeps going, to look at your zooming dial and make sure that when you let it go, it goes back to your original spot. its just like a stuck key, you just need to pop it back into place :)
hope this helps
Feb 01, 2010 | Fuji FinePix S1000FD Digital Camera
Wide screen mode won't go back to "normal".
Was exactly what you said. The cable box settings were in wide mode. Couldn't figure it out at all. Funny thing was too.. on my cable box remote, the button under the #9 button is the # button.. it doesn't say zoom at all.. but it totally controls the zoom.
So thanks for that.. AND thanks for saying "under the #9 on the cable remote" instead of just saying .. the zoom button.
Thanks again!!!
Dec 25, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony dsc t300 e 61:10
   The detail of fault is given below,
Self-diagnosis Code   Symptom/State
E 61:10         Zoom operations fault
               (Cannot initialize zoom lens.)
Correction :
Retry turn the power on by the power switch. Check the zoom
reset sensor of lens block (pin 9 of CN402 on the SY-191
board), if zooming is performed when the zoom button is
operated. If it is OK, check the zoom motor drive IC (IC401 on
the SY-191 board).
According to the symptom the possible fault is described above, You have to contact any nearest SONY SERVICE CENTRE to rectify the problem.
 Thanks for using fixya.
May 30, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Our Cinema series 32" TV is stuck on ZOOM and I can't get it back to regular. There is a ZOOM button but it doesn't seem to do anything. Ted Thank you
unplug tv for five minutes then return plug....now press and hold the tv power button for ten seconds(This should reset it!)
Dec 22, 2008 | Televison & Video
Panasonic AG-DVC10P zoom is stuck on max...
most likely cause of this problem is a stuck or defective zoom control. I have seen this one or twice. you may be able to disassemble the camera and free the zoom control if it is stuck, but it also may need to be replaced.
Aug 27, 2008 | Panasonic AG-DVC10 Mini DV Digital...
Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
Dec 02, 2006 | Sony Handycam DCR-PC105 Mini DV Digital...
Digital zoom not working
Digital zoom is in the menu and must be turned on to activate it. When you use the zoom it takes 2 opperations to function. First opperation is to zoom all the way in then the camera should stop. This is the limit of the optical zoom. Then you let off the zoom button, and hit it again and then the digital zoom will start. Digital zoom is just a gimic if you learn how it works its not doing anything different then you can do in photoshop. All digital zoom is doing is like cropping.
Apr 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Logo
221 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
