Question about Bedol International Group Checkmaster Checkbook Calculator
Instructions manual for a bedol checkbook - Bedol International Group Checkmaster Checkbook Calculator
User manual for a 3 memory bedol checkmaster calculator
What about the user manual? Are you saying you already have one? If so, why don't you read it?
Apr 21, 2017 | Computers & Internet
How do I turn off the alarm on the bedroll water clock
There should be some buttons on the back depending on what model you have you should be able to just press and hold one of them and then arrange the modes to your preference
Jul 31, 2016 | Bedol International Group, Inc The Bedol...
Do you still make the Bedol checkmaster 110-998
well someone might but we do not .search google.com
Mar 04, 2015 | Computers & Internet
How to set the time on a Bedol Squirt clock
The right button in the frame of the clock face is chooses mode; it cycles through alarm, date and time, in that order. The left sets alarm, date or time.
1)To set the time:
Press the right button 6 times until the hour display flashes. (Make sure it is the time and not AL = Alarm)
Press the left button until you have the correct hour (note AM or PM)
Press the right button again until the minute display flashes.
Press left button until you have the correct minute.
Press the right button then the left button; the colon should flash.
The clock is set.
2)To set the alarm time:
Press the right button twice until the hour display flashes. (Make sure AL is displayed in top right hand corner)
3)To turn on the alarm:
Press the right button once
Press the left button once
There should be a symbol which says "AL ON" near the centre top of the time display.
Press the right button 3 times until the colon flashes
The alarm is on.
There is also a way to get a bell symbol displayed at the centre bottom. (I didn't test what it does)
4)To set date:
Press the right button 4 times until the month display flashes.
Press the left button until you have the correct month
Press the right button again until the day display flashes.
Press left button until you have the correct day.
Nov 14, 2013 | Bedol International Group, Inc The Bedol...
Can't set a 3-tier Bedol desk clock.
1) Press the SET button until the hour blinks (I think it's 4 times)
2) Press the up or down arrow to change the hour
3) Press SET again to switch to minutes
4) Press up or down again to change the minutes
5) Press MODE to lock in the change
Very non-intuitive process ... frustrates me every time. Bedol is so cheap that they want $2.50 online for instructions ... couldn't provide an online manual for their products?? Geeesh ...
Sep 22, 2011 | Office Equipment & Supplies
My handyman took apart my Champion WQ120D paper shredder to remove the checkbook that was jammed. But it looked to him as if some transisters were burned. Once together again, minus a plastic shim at the...
It sounds like the shredder overloaded when you tried to shred the checkbook. If there is a smell of burned electronics this probably means that the shreader is dead. The plastic shims have nothing to do with the turning on and off of the shredder. Next time buy a shredder that is rated for at least 7-8 sheets, indicating a more powerful motor and sturdier blades. If the current shredder was repairable, it would be cost prohibitive over buying a replacement. Sorry for the bad news.
Sep 09, 2011 | Office Equipment & Supplies
Bedol International Group Checkmaster Checkbook Calculator Logo
119 people viewed this question
Top Bedol International Group Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Bedol International Group Office Equipment and Supply Expert? Answer questions, earn points and help others
