Question about Water Heaters
Manual for Baxi Boiler
I need the operating manual for a baxi boiler luna 3 avant 240 fi combi B73481058
    Champion:
  • 248 Answers
Any merchant will get one mailed out to you
Posted on Nov 06, 2009
  • mrhotandcold
    mrhotandcold Nov 06, 2009
    any merchant will get one mailed out to you
Baxi duotecHEa 40kw combi boiler made loud banging noises for 2 or 3 minutes then stopped. What might have been the problem
the banging is the water boiling/overheating Check the pump is working by undoing the large screw on the front of pump and gently putting a soft stick into the space behind to check that the rotor/impellor is turning. take care to catch the water which drips from the screw hole
Feb 02, 2016 | Water Heaters
Baxi boiler 80E low pressure on boiler how to fix it?
Silver flex hose may be the (correct) filling loop. There may be a valve at each end of it, maybe just one at one end.
Open the single valve slowly and LISTEN for the sound of water entering the system, and LOOK for signs of the pressure gauge rising.
On the dual valve version open the first, then open the second slowly as above. Close both valves when pressure is adequate. Adequate is determined by the specifics of your system, but note that more pressure DOES NOT mean better showers, etc.
It should only take a few seconds to top-up, any longer indicates a significant loss of fluid from the system.
Jan 28, 2013 | Water Heaters
How do i fix problem E119 on a baxi duotec combi 24HE - boiler won't light because of lack of pressure but I have no manual to assist me as the instructions on the boiler says.
http://www.bhl.co.uk/uploads/article1477/Baxi%20Duotec%20HE%20Combi%20Boilers%2024,28,33,40%20Installation%20Instructions.pdf top the pressure by the filling loop
Jan 23, 2011 | Water Heaters
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
1,517 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
