Question about Linksys Wireless-N WRT150N Router
Linksys N router drops signal
I have two lap tops with wireless cards. One has an a/b/g card, (Intel(R) PRO/Wireless 3945ABG Network Connection). The second has an N card (Intel Wireless WiFi Link 4965AGN).
Both computers will lose connectivity showing "limited connection" from time to time. I'd like to tell my Linksys WRT150N router to ONLY allow access at the "G" speed and see if that fixes the problem. I think I'm getting dropped becasue the access point drops me becasue it is monitoring a/b/g/n spectrums and it's too much. I did this at work and it seemed to work there.
Any ideas?
  • 88 Answers
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Posted on Feb 13, 2009
My Intel(R) PRO/Wireless 3945BG Network Connection , has a limited connectivity to the internet
Sometime when you switch on the computer and the wireless router (if you turn it off after using it) the computer does not get an IP address from the router in time when the computer finishes booting up. This problem may not occur all the time.
When you get the limited connectivity error, then right click on the wireless connection icon on the Task Bar and click REPAIR. This will get the wireless router to issue the wireless card an IP address.
Then you will have proper Internet connection.
Mar 09, 2010 | Intel PRO/Wireless 3945ABG Network...
Dell Inspiron E1505- Intel(R) PROSet/Wireless 3945BG Network. I also have Comcast Cisco modem and cisco Linksys router. I was getting an error "problem applying profile". I went to the contorl...
I had usualy solved mysterious problems with other intel PRO wireless cards not authenticating, loosing signal, etc, by simply upgrading to the latest intel drivers.
Also using the Intel connection manager instead of the windows or Dell/other notebook manfucaturer's product is far more reliable.
Hope this helps.
Feb 09, 2010 | Intel PRO/Wireless 3945ABG Network...
Do I need two wireless network adapters? I looked in the device manager folder in network adapters and there are 2... Intel (R) Pro/1000 PL Network Connection #2 and Intel (R) Pro/wireless 3945ABG...
You should have only 1 wireless adapter, the other 1 is the ethernet adapter. If you experience low signal strength even after updating the drivers, you need to customize wireless settings on the router.
You need to change the wireless mode to "802.11b and 802.11g" or "802.11g", whatever you have in your router. If this is the same with all wireless networks, wherever you go, then its an issue with the adapter, you should get a replacement.
Feb 05, 2010 | Intel PRO/Wireless 3945ABG Network...
Intel Pro wireless modem won't connect to my wireless router
Check whether the drivers for the motherboard is installed for the wireless Adapter card if it is onboard or if it is a PCI wireless card please reinstall the drivers using the software which came with that card. Thanks. It should work.
Jul 29, 2009 | Intel PRO/Wireless 3945ABG Network...
LIMITED CONCT.
If you are using an intel wireless card (such as the default wirelesscard coming with Lenovo laptops) you can download an "Intel WirelessConnection Utility" from the following intel download centre atfollowing location. Select appropriate operating system and downloadtype as "Software Applications" to download the connection utility. Install it.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+WiFi+Products&ProductProduct=Intel%C2%AE+PRO%2fWireless+3945ABG+Network+Connection&ProdId=2259&LineId=1784&FamilyId=1783
This tool from intel detects the available wifi networks and collectsthe authentication details and automatically connects when the networkdisconnects due to signal dropping.
You can think of changing the desktop/laptop network to "private"instead of "public" to avoid frequent signal dropping. Try to work froma place which is close to the router so tat the wifi signal is strong.
Feb 25, 2009 | NetGear WGR614 Router
Intel Pro Wireless 3945abg not connecting to higher speed DSL
router wireless limitations. if it was N type router it would go faster.
Oct 14, 2008 | Intel PRO/Wireless 3945ABG Network...
Lost signal
Saltypup77:
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Try going to the usb and the wireless adapter in device manager, properties. And make sure that the computer does not shut them off to save power.
Please let me know how you make out.
thanks
Jan 25, 2008 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-N WRT150N Router Logo
1,118 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
