Question about Canon VIXIA HF10 HDV Camcorder
When zooming focus becomes blurry - Canon VIXIA HF10 HDV Camcorder
3 Suggested Answers
  • 31 Answers
SOURCE: Pictures are coming out blurry sometimes depending on zoom
make sure there is no fingerprints on the lens glass
Posted on Aug 20, 2007
Rammsteins
  • 300 Answers
SOURCE: Canon SD850 focusing problem: When I zoom in, the
Sounds like some sand or other dirt inside the focus gears. There are very small gears in the focus system and even one piece of sand can block it at some point. The only way is to take it all apart and clean it under a microscope. I have repaired a lot of these. You will have to give it to a camera technician.
Posted on Jan 25, 2011
When i try to zoom in on a subject the image on the monitor is blurry
Check to see which resolution you have set as the lower the setting the blurrier the image becomes when blowing up the image
It could also be that the focus is slightly off and needs to be rest if possible
May 09, 2015 | Olympus Cameras
Why are my pictures blurry when focus is all the way out, and focused when all the way zoomed in? this is also visually obvious on the lCD screen. zoomed out( out of focus)..zoomed in( in focus).
your camera's lense is clear? try clean it with suitable cleaner for lense. If still not working, check your user manual for setting
May 09, 2011 | Cameras
While recording the Camcorder goes in and out of focus. If I keep the camcorder running and either zoom or pan out the subject refocuses, but if i hold at that level of focus the subject becomes blurry...
It sounds like you are either too close to the subject or you need to flip the focus switch to automatic.
The Auto/Manual focus button is located on the left side of the camcorder under the LCD monitor flap.
Other than that, does this happen only in low light? The camera will have trouble focusing in low light usually.
Mar 01, 2011 | Panasonic SDR-H40 HDD Camcorder
Brightness of the monitor screen changes when a picture is taken, the final picture looks blurr. Is there any solution?
Are you pressing the shutter button half-way and giving the camera time to lock in the focus before pressing the rest of the way? If not, the good pictures were just luck.
The overall image is out of focus
If Pan focus is being used, the image may be out of focus; use Auto Focus Mode.
Pan focus uses a focus range of several feet, so the image might be blurry but will be captured faster. This could occur in the EX-Z30, EX-Z40, EX-Z50, EX-Z55 and EX-Z57.
If digital zoom was chosen and the image becomes unclear, only use optical zoom, and move closer.
Check the owners manual; hope this helps.
Jan 12, 2011 | Casio EXILIM Digital Camera
JVC Digital Camera focus
Did it work before? If so then it sounds like the focus motor/screw jack has failed and needs replacing. With some JVCs you can replace the whole lens system and a new one will re-calibrate itself, but I'd have to check on this model.
Feb 07, 2010 | JVC GR-D770 Camcorder
WHEN I ZOOM IN (CLOSE UP HOWDO I GET A CLEAR
When you zoom in, you have to re-focus. If you get too close, you need to switch to "macro" mode. And, it becomes harder to hold the camera steady.
Sep 30, 2009 | Olympus Camedia C-755 Ultra Zoom Digital...
Focus and or Zoom problem
double check that its still in auto focus, i went a whole day trying to figure out why my camera wouldnt focus, and i had auto focus off
Jul 12, 2008 | JVC GR-D770 Camcorder
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Canon VIXIA HF10 HDV Camcorder Logo
26 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
