Question about Microsoft Xbox 360 Console
Unable to install HPw2007 Monitor
I just purchase the computer 1/22/09. Unable to install Monitor drive with sofeware provided. Please help!
Thank you,
Albert Evans
  • Aegis Kay
    Aegis Kay May 11, 2010
    PnP monitors shouldn't need drivers. What is the problem? Does the screen not come on?
I would like to inform you that if you are using HP PC, then there is no need to install the drivers from the disc provided with the monitor. HP PC already has in-built monitor drivers. The default account in Vista from first boot is an admin account, monitor should plug and play and the correct INF file will install for the monitor.
Still, if you want to install the drivers from the disc provided with the monitor, then please follow the steps given below:
== Disable UAC settings ==
You might get access denied error message while installing the monitor drivers.
The error message might come up if the UAC (User Access Control) in Microsoft Windows Vista is kept enabled, hence not allowing the installation.
To resolve the issue please follow the steps given below :
1. Click Start
2. Click Control Panel
3. Click User Accounts and Family Safety
4. Click User Accounts
5. Click Turn User Account Control On or Off
6. Uncheck the checkbox
7. Click OK
You will need to restart your computer for the change to take effect.
Now try to install the monitor drivers and check for the results.
If still the issue persists then :
Step 2 :
1. Click Start -> All Programs -> HP My Display -> Display Diagnostic Utility.
2. In the Display Diagnostic Utility click on “Clear Registry”. A Clean Reg Window would open, Click on “Yes”
3. On restart you will have “Other Devices” with “Generic Monitor” List under that same.
4. Continue the process of “Clean Registry” until you get “Other Devices” with “Generic Monitor” listed under that same.
5. Now insert the disc and install the drivers.
or Download the HP w2007 LCD Monitor Driver from the weblink provided below :
Now install the drivers.
6. Restart the computer.
7. This time it says "new hardware found with recommendation to install".
8. Cancel it.
9. Immediately, it gives option "Do not show the message again" and also says computer won't function if we select it.
Proceed by check marking it. You may be prompted to check mark it twice if prompted.
10. Restart the computer to check for the error message.
It will no more ask to install the monitor drivers.
Take your time, please try the steps and get back to us with the results.
Posted on Apr 10, 2009
Am unable to load software for camera into computer. Computer is new, purchased in Oct. 2017 with Windows 10. Am trying to load this software but nothing happens. Please help. Joan
Presumably you are getting an error message. If you can tell us what it is, or better still link to a screen capture image, we may be able to help. Thank you.
Dec 01, 2017 | Cameras
I just formatted my computer and audio dosent is a veiwsonic silver VA1912w monitor.please help
What I could recon from your question is that your audio driver is not installed in your reformatted PC.
Please be informed that any Driver software depends upon the PC make, Motherboard type and Operating System. You need to know all the three information's to do get going.
Please find the Driver software's of your Audio and video inside the installation disk provided with the PC at the time of purchase. As you have not mentioned your PC make I am unable to give you the direct download link. However you can download the same by visiting the website of the company that manufactured the PC.
Even here you need to be careful to download the correct software for your PC. You need to be exact with the PC make and Model number and the OS that you are using.
To install just Double clock on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Jul 22, 2011 | ViewSonic VA1912w 19" LCD Monitor
I have a Dell Monitor 2407 WFPb. The monitor went black unable to locate the various adjustment button (that you can only see when monitor is bright-because it's black unable to locate them, unable to...
Try unplugging it from the electrical outlet for about 25 seconds. Then plug it back in and go to your settings if the power button turns the monitor back on if it does not work try it on another working computer. Sometimes this happens when the settings are two high of resolution when your graphics card cannot handle it. Hopefully the issue is not the monitor going bad. Thanks for using FixYa! Do not forget to place a vote for me if I helped you in any way. John
Mar 25, 2011 | Dell UltraSharp 2407WFP 24" LCD Monitor
I get the following problem during installation 1607: Unable to install installshield scripting Runtime. please help me
Unable to continue or unable to install with this program are searching for support on it. Runtime errors are common in system registry which a certain is missing or broken.
There are some causes on it.
  1. Confliction with TSR or other running program.
  2. Software Issue
  3. Computer Virus
  4. and Memory Use.
To fix it here is a link to help you:
This one can repair all broken DLLs in your system.
Please rate if i am helpful to you.
Thank you.
Sep 01, 2009 | Peachtree Software Accounting 2005 for PC
I am unable to make resolution 1024 x 768 in lg model 500G
If the monitor is somewhat old and the monitor hardware doesn't support 1024x768 resolution, installing a new driver won't help. You will have to switch to a better monitor.
Dec 21, 2008 | LG Studioworks 563N 15" CRT Monitor
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Monitor Problem
windows boot sector is damaged you need to reload windows from a cleaned hard drive, reformat the hard drive then install windows
May 09, 2008 | Compaq fs740 17" CRT Monitor
Purchased computer model Elite 9070a have been well serviced with HP products this being 3rd HP computer we have purchased. However am very disalusioned with Vista program and wish to replace with windows...
You sound like you tried to install XP with Vista running - this will generate the message that you have received.
To install XP on your system, insert your XP disk into the computer and then restart it.
Select Boot From Disk during start up and this will lead you into the XP Installation.
Xp will not recognise Vista and will just overwrite it - deleting the current OS and formatting the C:\
Good luck.
Apr 23, 2008 | Computers & Internet
Graphic resolution problem
Please install the software that comes with your new monitor. And try adjusting the correct resolution from the monitor buttons / as well as from your Windows operating sysytem to suite your monitor.
Mar 05, 2008 | Intel Motherboard
Microsoft Xbox 360 Console Logo
320 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
