Question about IBM Computers & Internet
IBM 6252 Keeps Losing Power, Need Service Manual
Hi There, My IBM T40 Think Pad keeps on losing connection with hard disk frequently, Before i tried to remove it & Reattached it again & it has worked, But now it's not helping any...
If the hard-drive is losing connection even after removal you should test to make sure that the drive is still functioning.
Try to see if your system has an on-board diagnostic, (f12 on startup, before the windows loading screen) this will tell you if the hard-drive itself is actually broken, or if it is just a connection.
Mar 15, 2011 | IBM ThinkPad T40 Notebook
My DVD receiver HT762 does not switch ON. initial check on the power supply shows 330V DC on the first power supply. The next supplies using flyback regulator IC 6252 and UC3844 do not work. the voltage at...
Why is there 330 volts? Most recivers work off 250volts AC, so why would it need 330 volts! Seems to me that whatever is producing that 330 volts is the bad guy that is causing the trouble, unless you live in some part of the world that uses a voltage higher than 250!
Jan 27, 2010 | Audio Players & Recorders
Keep losing wireless connection
probably not your computer problem
probably its the net
does it happen every where' or in singal net?
Oct 01, 2009 | IBM ThinkPad R52 Notebook
I keep losing my connection - IBM Thinkpad t42
Are you using IBM SW or Windows to manage the wireless? Occassionally, the IBM SW has issues with certain model routers and encyrption types.
You can also try unchecking the "Allow Computer to turn this device off to save power" in the adapter properties and
Adjusting the power on the wireless device to the max. By default IBM sets it in the middle to conserve power.
Mar 03, 2009 | IBM ThinkPad T42 Notebook
I have shady spots on my trutech 36"flat panel
This is usually a sign of a bad power inverter circuit or back light lamp. These problems should be checked out by a service center. They should be able to determine if you need to send in you television in for service. You can reach Tru Tech Customer service at these telephone numbers. 1-888-252-6252 and 1-800-252-6123. I hope this helps you with your problem.
Nov 02, 2008 | TruTech PLV16320 Television
Trutech
You should be able to find the answers for this problem in your owners manual. They should have a section on how to operate your television without using the remote.If you cannot find the answer there , try calling these telephone numbers for TruTech technical service : 1-888-252-6252 and 1-800-252-6123. I hope this helps you with your problem.
Sep 30, 2008 | TruTech PLV16320 Television
Power-on password problem!
The power on password is stored on an EEPROM chip and removing the BIOS/CMOS battery won't help.
You need to read the EEPROM chip to get the password.
GOTO
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
for solution to your problem (you need to construct an interface hardware and install two programs on a working computer)
Have fun
ChrisH
Dec 28, 2007 | IBM ThinkPad T23 2647 Notebook
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Computers & Internet Logo
47 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
