Question about Roper RAS8445KQ Top Load Washer
Washer makes noise
It makes noise when washing or spinning like the adgitator is stuck
  • Roper Master
  • 8,220 Answers
You may have a problem with the coupling
Posted on Mar 07, 2009
Washer wont adgitate
Hello Lisa Kauffman - There are a few factors that can cause the unit to not spin. Is the washer making a humming noise? If so, either the drainage hose or pump may be clogged and needs cleaning. Otherwise, the unit may also possibly be experiencing an issue with the control board not communication correctly, faulty pump, timer, or, defective door lock assembly. If I was in your position, I would contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified tech through the manufacturer website.
Feb 26, 2013 | Frigidaire FEX831CS Top Load Stacked...
Washing machine dose not aditate anymore
pull up the agitator, you may need to get a belt wrap it underneath and yank it up, please be careful that it doesnt hit your eye and under the agitator is a coupler or bell that needs to be replaced, it is stripped, loosen the bolt and replace
Mar 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
Noise when high speed spin cycle
maytag washer makes a noise when washing or spinning. sounds like a screw is stuck or maybe a bearing is going. It is getting worse each day.
Dec 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
My machine will just stop after the adgitate cycle.
Manually turn the knob to the spin cycle and turn it on.
If it does not spin, replace the lid switch.
If it does spin, replace the timer.
Feb 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper RAX4232KQ0 maker loud noise at spin cycle and then stops
There are a few things that can go wrong, If the washer doesn't adgitate or spin then probably the coupler is broken, lean the washer back and look under the machine between the motor and transmission you will find the coupler. (very common)
Coupler Part# 285753A $22.95
If its agitating but not spinning, check the lid switch, (easy check just listen for the click when you shut the lid, Or you can bypass it with a jumper wire under the console there are only 2 screw that hold the console down they are philips and either located in the front lower corners or the back lower corners)
Lid switch Part# 3949247 $42.95
If lid switch is good and the motor still doesnt run you might have a bad timer (RARE)
Timer Part# 3954563 $95.95
If you can hear the motor running but its not spinning and you have rulled out the coupler then your probably looking at a clutch (common problem) either the clutch isnt grabbing or the brake isnt releasing both problems solved with the clutch kit
Clutch kit Part# 285785 $44.95
Worst case your looking at a transmission, (uncommon) to rule out, make sure its agitating, then put washer in spin cycle. look under the washer to see if the clutch bell is spinning. if its not then you will need a transmission.
Trans Part# 3360629 $172.95
if its making loud noises when it stops spinnig then the block is bad.
Block Part# 389140 $14.95
Feb 07, 2009 | Roper RAX4232KQ Top Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine not draining
If you are confident you can do it pull your pump off washing machine and pull the pump houseing apart most will come apart and make sure there is nothing in the pump maybe a small piece of plastic or other item in it. you could also try taking the hoses off the pump and just flush water through it backwards this will also sometimes work I have come across this a lot and normally it is something in the pump interupting the water flow. There may also be sand or small pebbles in the drain holes under the adgitator if flushing the pump doesn't help check under the adgitator for something in the holes. Hope this helps
Jul 21, 2008 | Whirlpool LBR4132JQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
66 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
