Question about Hitachi 46F510 46" Projection HDTV
Can an amature replace a convergence board?
  • Hitachi Master
  • 3,459 Answers
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Posted on Jan 29, 2009
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
When I turn on my tv the picture is distorted for about 5 minutes and then is fine. Can you help? Thanx!
It sounds like bad solder connections in the convergence section but that depends on what you mean by "distorted" - do the colors become misaligned (especially visable with on screen print)?
if so see below info:
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Nov 05, 2009 | Toshiba 57HDX82 57" Rear Projection HDTV
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
Blue shadow
If it is a projection TV , like the model in title, then it is not a convergence problem.
Describe the problem in detail and confirm the model number for the TV.
Oct 02, 2008 | Akai PT4298HD Rear Projection Television
Sony kp51hw40 rear projection wont converge
You need to replace both Ics numbers STK392-560 they are located on large aluminum heat sinks on the D Board. You can get replacements at the following link and they provide free instalations instructions with pics so you can easilly do the repair yourself. Heres the link.
May 10, 2008 | Televison & Video
Its a straight forward repair just take out the convergence ICs and solder in two new ones. takes about an hour from beginning to end. just apply heat sink compound on the new ICs before installing them. And in that model check the resistors right next to the ICs as 1 or 2 of them often burn open when the ICs go out. Let me know if you need any additional info. The ICs cost about 10.00 each you will ned two.
Mar 23, 2008 | Philips 43PP9202 43" Rear Projection...
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Feb 28, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Picture problem
If this is a ctc 195 chassis then your likely problem is the convergence power supply that is mounted above the main board and the dynamic convergence board. On the board is an IC (usually) that can be changed: STK 730-010 I believe is the correct can check the number, If it has a single transistor on the metal heat sink, I would suggest changing the whole board. Has only two plugs: one on each end of the board.
Dec 29, 2007 | RCA P52955 52" Rear Projection Television
Remove the front grill. There are 2 screws on each corner accesable from the rear and 2 screws inside the front door. Push down on the grill and it will unsnap. Remove the pressboard coverplate . You should see the convergence board, it is about 12" long with a big aluminum heat sink. The board can be removed by pressing on the tabs that hold it down. Be sure to mark and unplug the molex connectors from the board. One of the connectors has to be unplugged from the chassis because it is fixed to the board. Once removed you can easily get to the IC`s mounted to the heat sink. Check for any burned resistors near the IC`s.( 2.2 ohm likes to burn) The convergence can be done through the customer menu using the remote. There is no special formatting necessary. Use the number pad to navagate and the select key to change red & blue.
Nov 06, 2007 | JVC AV-48WP74 48" Rear Projection...
43fdx01 hitachi
possible convergence overdrive from the IC's. This will cause the symptom you describe. ....accordianman
Jul 17, 2006 | Hitachi 43FDX01B TV
Hitachi 46F510 46" Projection HDTV Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
