Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Dispenser ice/water not working
1-no volts at h2o valve 2-new filter 4-continuity at dispense switch 5-continuity at on/off dispense switches 6- no volts at dispense switches 7-light at dispense not working 8-ice maker ok plenty of ice at catchtray
    President:
  • KitchenAid Master
  • 2,651 Answers
???? no ice dispencing?? no llight whenthe paddle is dpressessed?? if this is the case, i would look to the wireharness under the freezer door, there should be quick disconnect just under the refrigerator. after disconnecting check for broken wiring right under the hinge
Posted on Jan 24, 2009
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
Whirlpool French door not making ice, but can get water. I had the water valve replaced and it still does not make ice help
Okay, here's a bunch of info in the order I would troubleshoot since the one year warranty expired.
1) The water filter might be clogged. Try just removing it to see if it makes ice. If it does change the water filter.
2) The water inlet valve might (still) be defective. The water inlet valve is an electro-mechanical valve. The coil can show good for continuity and still not let the water thru although you didn't say if it worked when he left. if recently replaced it should be under his warranty.
3) The water pressure in the house might be too low. The water inlet valve which supplies water to the ice maker is designed to work with a minimum of 20 psi of water pressure.
4) The door switch might be defective. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker and dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
5) It could be that the ice maker assembly itself is defective. The freezer temp should be between 0-5 degrees for the ice maker to cycle properly. There are several components in the control module of the ice maker that can fail and most are not sold separately. Also, ice makers have a relatively short lifespan and so it might not be worth fixing. If other, simpler parts like the water inlet valve or shut off arm have been ruled out, and the only thing left is the ice maker itself, replace it as a unit. Not as expensive as you may think...Under $100
6) The icemaker module at the front might also be defective. The module has a motor that cycles the ice ejector arms around to push the ice cubes out when the ice maker thermostat closes. It also has contacts in it for the mold heater and water inlet valve. The motor or contacts of the module can fail. Usually there are test points in the module that a service person can use to determine if there is a problem with it or one of the related ice maker components.
7) The icemaker mold thermostat might be defective. Inside the control module of the ice maker is a thermostat which monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature the ice maker starts a harvest cycle by ejecting the ice cubes and refilling with water. If the mold thermostat is defective the ice maker doesn't advance. The thermostat can be checked for continuity. Replace it as needed.The freezer temp should be between 0-5 degrees for optimum performance.
Sep 17, 2014 | Whirlpool Gold GI6FARXXY 25.5 cu. ft....
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker and water dispenser
If the refrigerator water dispenser is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 06, 2014 | Samsung 33 in. W 24.7 cu. ft. French Door...
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Jun 02, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps flowing when water source is turned on
HI,
I have a little experience on your problem.S i suggest you to ask another experts advice.
Jun 13, 2008 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
109 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
