Question about Garden
3320 John Deere Parking Brake will not release
2007, hydrostatic 4 wheel drive
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
  • 112 Answers
SOURCE: I have a John Deere GT225. The hydrostatic drive
sounds like your linkage is disconnected, With the tractor off raise the seat and back panel (if possible) and work the shift and look for failing linkage.
Posted on Jul 25, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
wireguy212
  • 1627 Answers
SOURCE: error code 74 on john deere 3320 tractor
Lcd display switch is stuck in the on position either play with the switch until the code goes away or have the dealer replace the switch,it should still have warrenty.
Posted on Dec 02, 2009
wireguy212
  • 1627 Answers
SOURCE: where is the hood release for the 3320
Below the bottom of the hood you will find two metal tabs,push down on either one to release the hood.You will have to release the grill guard pin and roll it forward before the hood will open all the way[if it has a loader on the tractor].Under the hood and to the left of the battery is the prop rod to hold it up.Hope this is helpful.
Posted on Jan 02, 2010
My 1908 John Deere 425 Zrider, Shuts down when releasing parking brake.....baffled!
start check the safety switches ---seat--brake--pto /blade engagement --
Jun 08, 2017 | John Deere Garden
Engine shuts down when petal is released
Sounds like your "dead man" switch is bad. Should be a switch under the seat that if you are not sitting on the seat will shut off the engine when you get off unless parking brake is set.
Jan 11, 2014 | John Deere 195HP Hydrostatic 42" Cut...
I have a 2008 John Deer X300 riding mower. I parked it and when I went to use it the next day would not move forward or backwards. It is hydrostatic. What could it be? How do I check fluid for hydrostatic?
Sounds to me like your hydrostatic control lever has became disengaged. If you had a fluid problem yuou would probably find fluid on the ground or within the tractor chasis somewhere. I,d check the linkages for your problem. Also make sure your parking brake is released.
Sep 13, 2010 | John Deere Garden
There is no parking brake, and "park" does not hold. it is a 1990 cruise air lll on a john deere chassis with a ford 460 engine.
The parking brake is activated by the shift lever. There is no parking paw in the transmission on these John Deere Chassis motor homes. The parking brake is the type that works a brake on the drive shaft. I ran into the same problem and just put a line lock on the brake line.
Sep 01, 2010 | Ford E-350 Super Duty Cars & Trucks
What would cause the mower to hold back and make roaring noise and hardly go john deere model lx 279
A stuck brake maybe.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 19, 2010 | John Deere 195HP Hydrostatic 42" Cut...
Brake pedal won't release on a John Deere 316 lawn tractor
I have the same problem. I just wiggle the black handle on the parking brake release. It usually allows the pedal to come back up. One of these days I'll see what hanging up in the linkage.
May 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
The parking brake on my John Deere L118 is stuck in the activated position. Therefore the tractor won't roll. How can I disengage the parking brake?
Usually there is a red handle under the steering colunm that locks the pedal down. You will need to depress the brake as you push down on the red handle which should release it.
Oct 11, 2009 | Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
