Error code C0070
Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
  • 1 more comment
  • plumbdum Jan 24, 2009
    Thank You, Cogz. You are a gem. Yes, I had just added a new toner. Followed your instructions and copier is back to work.
    Thank you again.
  • Anonymous Mar 31, 2014
    c0070
    a malfunction was detected.please provide code C0070
  • 1,326 Answers
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Posted on Jan 24, 2009
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
Copier malfunction
Have you just added a new toner? If so try this first.... Turn the power off and carefully remove the toner bottle you just put in.. Close the front door and turn the power back on and let the copier warm up to ready. Make one or two copies and open the front door and reinstall the toner bottle again... That should take care of the problem.... If it dose not work you probly have more of a major problem with the hopper unit..
Jun 18, 2009 | Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Not working
C0400, Exposure lamp failes to turn on. The lamp under the exposure glass is burnt out or the thermal fuse for the lamp has blown. Ohm out the lamp and fuse, replace as needed.
Apr 15, 2009 | Office Equipment & Supplies
Service code C0B52
1. Turn off copier 2.Disconect finisher cable 3.Turn on the copier . If it works properly turn it off &reconnect finisher cable then turn it on .
Apr 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep5000 cspro
What you need to do is to take the new toner out bottle out and close the front door and let the copier come to ready again and then try to reinstall the toner bottle again and run the copier... Basicly, the toner bottle was put in wrong and you have to let the hopper go back to home postion and then reistall the toner bottle
Dec 05, 2008 | Office Equipment & Supplies
Minolta CSPRO EP 3050 turning it On appears display Code: C0200
A C0200 is a problem with one of the coronas - could be the charge, transfer, or separator.
First try resetting the code by opening and closing the main front door with the machine powered up and the error code showing. This should make the code go away.
It may or may not come back. If it does, clean the coronas.
It is necessary to remove the drum assembly in order to access the charge corona.
The EP3050 originally came with a self-replacing charge corona. It actually had a small spool of corona wire in the charge corona assembly, along with a small motor that advanced the wire every few thousand copies. This was prone to malfunctions, and there was a retrofit kit which replaced the whole thing with a conventional wire.
If you still have the code, and have no idea what I'm talking about, then it is probably time to call a technician. :-)
You will need to call an independent, as Konica Minolta no longer supports this model.
Nov 12, 2008 | Minolta EP1030/1030F CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
679 people viewed this question
k24674
