Question about Yamaha R-S300
Yamaha r-s300 power flashing red - Yamaha R-S300
Recently got a Yamaha R-S300,can i connect other sysyems to this receiver or do i need to buy all yamaha gear separately
You will need to get the optional Yamaha iPod dock if you want to use that feature, but otherwise you can use any brand of components (CD player, tape deck, speakers, etc.) you want. If you stick with all Yamaha components, you might be able to get by with a single remote control, but that's about the only benefit. Using different brands means you might need a table full of remotes for them, but they will work.
Jan 14, 2011 | Yamaha R-S300
Have purchased Terminator Salvation and 2012 on bluray, both Sony discs, they load and go to menu screen, however the icons to allow you to play or scene select etc do not appear, menu just plays over and...
Most likely you need to 'flash' (update) your BDP-S300's firmware. I had the same issue while trying to play AVTR in my BDP-S300. I downloaded Sony's latest firmware update, burned it to disc and popped the disc into the player... It takes 5-10 minutes for the 'flashing' to take place. AVTR now works in my player... Had to do this with one other Blu-ray movie about 18 months ago also.
Download the latest firmware version for the BDP-S300 here...
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=BDP-S300%20®ion_id=3
Follow the instructions to the letter!
If you have any problems with updating your BDP-S300 firmware, feel free to contact me at bambu@rogers.com
Apr 27, 2010 | Sony BDP-S300 Blu-Ray Disc Player
My printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
Jul 23, 2009 | Canon BJC S300 InkJet Printer
My Canon S300 printer is flashing green, then 8 oranges flashes (waste tank almost full). What exactly do I have to do to resolve the problem?
This procedure will print out information about the EPROM:
2 EEPROM information printing
a) While the printer is powered off, hold down the RESUME button, then press the POWER button.
b) When the POWER LED lights up, hold down the POWER button, and press the RESUME button twice.
c) Release both the POWER and RESUME buttons, and the service mode is entered.
<< Note: the printer will cycle through and then the power light will stay on steady>>
d) Press the RESUME button twice.
e) Press the POWER button.
==>EEPROM information printing pattern will be printed.
If a report is printed, then you know you have done the steps correctly. The top line of the report will look like this:
S300 P=V 1.00 Destination=000.0 D=095.5 Page=05716 CH=0000 BK=(000) C=(-01)
The number after "D=" is the waste tank counter. To reset this to zero, repeat the steps above except for step d) you will press the RESUME button four times. (Also, you may have to press the POWER button in step e) twice).
Repeat the steps to print the information and the counter number should be zero. Mine changed from the above line to this:
S300 P=V 1.00 Destination=000.0 D=000.0 Page=05717 CH=0001 BK=(000) C=(-01)
Nov 16, 2008 | Office Equipment & Supplies
SONY BDP-S300 unlock region code
DVD PLAYER SAYS CANNOT PLAY THIS DISC
Apr 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
CFD-S300 Sony Boombox lost power cord
Purchase online at Sony.com, parts and accessories.
Jan 03, 2008 | Sony CFD-S300 Radio/Cassette/CD Boombox
Low voltage error indicated
Bad main PCB, send in for service. 95.00 Flat rate repair.
Agson 856-751-9048
Aug 09, 2006 | Citizen CT-S300 Printer
Yamaha R-S300 Logo
42 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
