Question about Kenwood DNX7120 Car GPS Receiver
How to enter code request - Kenwood DNX7120 Car GPS Receiver
Autocad 2006 serial no 400-12345678
hi! nothing sushma! first  do  onething disconnect ur system from  the internet then enter that serial num  653-12354321 or 666-98989898 or 666-69696969 then   it ask request code please enter  the code :     YC3H N4QZ TNF1 7EP3 G6WF 8WGU 06V6 QRAY Z02C 5FWK YUXQ S4V4 15CZ N0LD PJTY SA5J KZH5  (or) z9nn d3k3 6tyl 6vp3 wwqv 2nwd
still facing problem on activation  dont worry! first  uninstall autocad completely! then install autocad with serial number 111-11111111   then u note ur request code that shows  in the offline activation option! then kindly mail me ur request code! i will send ur activation code for ur request code as soonas possible for free..!  mail me if ur willing ,my mail id:rameshprabu@in.com
plz rate or comment me if u like my solution..! thank u for this opportunity..!
Aug 16, 2011 | Autodesk AutoCAD 2006
I gt a wrng pin code n nw sim is blockd askn 4 puk code
PUK Code, is the PIN Unblock Key. This is automatically applied to your phone for security reasons when the PIN itself is entered wrong a no. of times. As this code is specified by the Network Provider, you have to just contact your customer care and request them for your PUK Code. They will give it to you with ease.
Thank You.
Mar 07, 2011 | Cell Phones
Never received security code trying toget back on facebook. keep asking for secirty code which i never received
You may request a new code by selecting the "Verify" link found below the "word in the box" (i.e., the captcha) that you see when sending friend requests. Alternatively, you can request new codes here. When you enter your phone number, select your country code then enter your number without any special characters (+ or -) or leading zeros at the front of your phone number. Once you receive this code, enter your code in the Code field and click the "Confirm" button.
If you see a message that says you have reached the code limit, please wait a couple of days and try again.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 31, 2010 | Facebook Social Network
SGHE490 is requesting me to enter a security
Try 0000 or 00000 or 000000
Good luck as you try.
Jan 13, 2010 | Samsung SGH-D600 Cellular Phone
Panasonic dvd-s54 unlock code to make it play region-free
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__uji8
Dec 27, 2009 | Panasonic DVD-S54 DVD Player
How can i change regional code on panasonic sc-bt207
Regards, Jay__yhg6
Nov 16, 2009 | Panasonic Home Theater System System
Change DVD Region Code
Regards, Jay__okj4
Oct 15, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
I can't remember my unlock code on my sms
sometimes it defaults to the manufacturer security code "000000" or "1234"
also try the last 4 digits of your phone number.
Mar 18, 2009 | AT&T Motorola RAZR V3 Cell Phone - Black
Security code
The default 6-digit security code for this phone is 000000. Hope this helps.
Feb 02, 2009 | Motorola Mobility RAZR V3
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
Jan 10, 2009 | LG Shine KE970 Cellular Phone
Kenwood DNX7120 Car GPS Receiver Logo
15 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
