Question about Pyle PLTS76U Car DVD Player
CONNECTING AN AMP
WITH WIRE DO YOU CONNECT YOUR AMP TOO? THERE NOT AN AMP WIRE ON THE HARNESS
    Scholar:
  • 116 Answers
Amp is powered by a main power wire to the battery, ground to metal chassis, and a remote wire (usually blue) from the D player to the remote in on amp. RCA's from CD player to amp as well. Not sure what you mean by "no amp wire on harness". Let me know so I can give you a more definitive answer.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • Kenneth Ross
    Kenneth Ross Aug 24, 2010
    I just spoke with Pyle, on 8/24/2010 @ 1:25pm CST, and they told me that the BLUE ANTENNA WIRE, doubles as the remote turn on wire.
Need to know from top left to bottom right what each wire goes to on power plug on jensen car stereo model vm9311
Hi Jeff, Thanks for the question. When wiring an aftermarket car stereo I always recommend purchasing a wiring harness that will connect into the vehicles existing harness, Then you only have to worry about connecting each wire to it's color coded counterpart. With that being said, if you do not have the stock harness I can explain the wiring colors to the best of my memory
Red = 12v Memory power
Yellow = 12v Constant power
Black = Ground
Blue/white = Power Amplifier
Blue = Power antenna
Grey = RF speaker (+)
Grey/Black = RF speaker (-)
White = LF speaker (+)
White/Black = LF speaker (-)
Purple = RR speaker (+)
Purple/Black RR speaker (-)
Green = LR speaker (+)
Green/Black = LR speaker (-)
Sometimes there is a dimmer wire also, usually orange or pink I believe
I hope this helps, & Thanks again!
Feb 18, 2014 | Car Audio & Video
I CONNECTED MY RADIO TO WIRE BUT I DID NOT GET SOUND FROM THAT AND ALSO MY ATTENA IS NOT ACTIVE
if you are connecting an after market radio harness to a harness that connects to the factory harnesses make sure to connect the blue/white wire to the blue wire.
May 05, 2011 | Car Audio & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Amp wont produce sound when car is on only when car is off it works
Ok do this little experiment when you turn on the car again disconnect the amp turn on wire from the amp. then get a small wire then strip back both ends with a wire stripper only exposing enough for the copper wire to show. then touch one end to the 12volt on the amp and touch the other end to the amp turn on terminal. The amp should come on and the sound should come on. Your problem then is your amp turn on connection is wrong and may be connected to the power antenna wire which may not be able to handle the load and shuts off so I suggest connecting it to the ignition wire so whenever the radio is on that wire will send 12 volts to the amp to turn it on. Sometimes On the back of the radio harness there are two blue wires. One is Blue and the other is blue white. Always connect it to the Blue white cause thats the amp turn on wire. The solid blue wire is the power antennna wire. Also possible the blue/white wire is sending a weak 12volt signal so just connect it to the red wire which is the ignition wire. Dont connect it to the yellow wire because thats constant 12 volt. If you connect it there the amp will always be on and drain your car battery and you might hear big loud buzz sound when you turn off your car.
Apr 07, 2010 | American Pro VS1405 Car Audio Amplifier
How do I connect it?
you need to figure out where the wires go and to what type power they are connected. if you look in the back of the stereo where the wires are(the ones from the radio harness), these are the main ones(yellow=12v constant) this one keeps memory for your radio. This one shouldn't be used to connect to your amp. Find out if the amp had a dedicated power wire directly from the (+)battery to the +12v connection on the amp. The other is the remote wire(it's always blue in color from the radio harness). it goes on the remote connection on the amp, when the radio turns on, so does the amp and when radio is off the amp is off. The last is the ground(black)wire. Connect this one to the car chassis(any bolt on the car, i usually use the seat bolt. Now the rest of the wires are for sound. The rca's go from the "output" of the radio to the amp's "input". What's left is connecting the speakers, that's the easy part, just make sure you trace all your wires and if you have to pull the stereo out of the dashboard to verify the connections...do it. This will save ensure that the job is done not only right, but safely. get a probe light tester from autozone or any parts store to check your voltages before you connect the wires. Better safe than sorry. Seems like a lot but it's really not. good luck.
Oct 06, 2009 | Pioneer GM-X324 Car Audio Amplifier
Where do i connect the power control wire to ? I have a kenwood amp kac 7202, I'm connecting it to a stock cd receiver in toyota corolla 2004
Hello sophnettliss,
Most stock receivers do not have a dedicated amp remote lead and your 2004 Corolla is no exception.
The amp remote can be connected to any switched and fused 12V + source including the OEM receiver accessory wire which is the gray wire in your receiver harness.
Hope this helps.
Oct 02, 2009 | Kenwood KAC-7202 Car Audio Amplifier
We are replacing the fuel filter in a 98 pontiac transport. The new wiring harness came with a purple, grey & 2 Black wires. The OE harness comes with purple, grey , black and a white/black. How do you...
Assuming you mean replacing the fuel PUMP, the 2 wires are different guages. Connect the lighter wire to the lighter wire and the heavier wire to the heavier wire. If the new harness uses both the same size wires, the heavier wire on the vehicle side (solid black) is for the fuel pump ground. Lighter wire is for fuel guage sending unit.
Sep 21, 2009 | 1997 Pontiac Trans Sport
I need precise information on connecting the parking brake wire on the clarion vx409. Do i connect it to the parking brake button or do i connect it to the light on the instrument pannel / dash. Also what'...
Connect your parking brake wire to the ground side of the parking brake switch above the pedal, or at the parking brake lever. As for the the illumination wire, if the wiring harness on the factory side does not have illumination wire, ignore it. It is only used to dim the screen when you turn you lights on. If you really want the feature and do not have the lead on your factory harness. Run it to the headlight switch and connect it to the positive lead
Aug 28, 2009 | Car Audio & Video
Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
Pyle PLTS76U Car DVD Player Logo
167 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
