Question about Dell Dimension 2400 PC Desktop
My CD drive is not working
I took it out once for a day,when i placed it back in the computer it was not showing up.the power is workin, it is opening and closing but it is not showing up
  • Dell Master
  • 1,183 Answers
kindly follow the troublesooting in the following link
http://tinyurl.com/bu9qgs
thanks
proton
Posted on Jan 24, 2009
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
Tip
Dell vostros 220 cd/dvd drive not working
my cd/dvd drive quit working device manager showed the triangle and ! mark, properties showed code 10. shut power off, took side case off, unpluged both cd/dvd's, from the board, restarted machine let it reboot, shut power off again,plugged both cd/dvd's back in, restarted machine, both were reinstalled and now working. hopes this is some help to somebody else. thanks jim.
on Jun 22, 2011 | Dell Vostro 220 Desktop Computer
Well....my computer is not showing harddisk in bios i dont know what problem can be thatswhy my computer is not running and showing in starting error of "drive 3 not found unknown pata 1 "...
hi first open the case make sure the power is not plug in. second look for the hard drive , it s right next to cd rom right corner , make sure the data cable ribbon is correctly seated next , check the power make sure its connected . now the fun part is next . here how your going to find out if you hrddrive is working remove the ribbon data cable from the cd rom also the power ,now remove the ribbon from the hard-drive next place the ribbon from the cd rom to the harddrive next make sure ever thing connected right . power the computer go to the bois and see if the hard drive is being read. if it is then ribbon bad ,ifnot your hard-drive is bad if is bad put ever thing back in place take your hard drive out and replace with same bigger gb thanks hope this helps
Oct 27, 2010 | Dell OptiPlex GX280 PC Desktop
Speakers and mic input not working anymore
Have you done a windows update recently? It could have been caused by a updated driver that your computer doesn't really like.
Or is your output device set to digital instead to analog?
Aug 07, 2009 | Toshiba Satellite 3000-S353 3005-S303, and...
Computer does not recognize CD/DVD drive
If updating the drive firmware does not work, then replacement of the drive will be necessary.
Jan 30, 2009 | HP Pavillion ZV6000 Notebook
Disk (CD) will not eject automatically nor play a CD. It make noise, (a clicking),trying to eject. In my computer, it will not show that the CD is in the drive.
Turn the power off before you try this. There's a small hole in front of most CD drives. You can straighten out a paper clip and try pushing it into the hole. It should go in about 1/4 to 1/2 inch and then stop. Press just a little harder and it may push open the tray and eject the CD. If there's not a CD in it, it may move it enough that it will reset itself. Once the tray is open, and the CD removed, you can power on your system. It should pull the CD tray back in. Once your system boots, try the eject button to see if it works.
Dec 02, 2008 | Everex Computers & Internet
My computer does not show my D:/drive, so it does not work
I would assume that your D drive is your CD Rom Drive. If you go into My Computer and the drive isn't there, Lets assume first that there is a problem with the Drive. If you have power to it and the drive does open to let you insert a disk, then our next step is to see if your data cable running to the drive is connected. Make sure that all power cables are unplugged before you open up the computer. Once opened look at the back of the CD Rom drive to check that the power plug is connected. Its the first set of 4 wires closest to you. The next cable next to that is the CD Rom Data IDE Cable. This cable must be plugged in all the way. Most of the IDE Cables will have a red stripe on one side. Make sure this red stripe is closest to the power cable for the drive. This will insure that you have this plugged in correctly. If you follow the IDE cable from the CD Rom to the mainboard (Motherboard) , you can make sure that this end is also seated firmly to the board. If all this is as it should be, go ahead and plug all your cables back in and restart your computer.
If this still doesnt solve your problem you might want to check your bios and insure that the CD Rom is recognized. It will show up in there if it sees it. If any of these solutions dont solve your problem, I would be leaning toward a bad CD Rom Drive.
Joe < Data Miner >
Nov 01, 2008 | Computers & Internet
Mitsumi cd-rom fx4821t wont work
have you installed any software for compiling the data and writing it on the disc....
try to use nero and tell if it shows any error
Aug 31, 2008 | Mitsumi (CRMC-FX4821T) (crmcfx4821t)...
Unreadable disc
Try a new game it might work.
May 09, 2008 | Microsoft Xbox 360 Console
Dell Dimension 2400 PC Desktop Logo
18 people viewed this question
Alun Cox
