Is it a simple orifice change to convert a lennox pulse 21 to lp from nat. gas
My friend installed a used furnace but i don't think it was ever converted to lp. and that it what he is hooked up to
SOURCE: Orifices - parts
An LP gas technician can take your old orifice, fill the hole, and redrill it to the correct aperture for LP gas. Usually only a couple of bucks.
Posted on Nov 06, 2008
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 8 Answers
SOURCE: 2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Posted on Jan 20, 2009
  • 14 Answers
SOURCE: Problem converting regulator from Natural to LP Gas
Flip it over with LP side facing up
Posted on Feb 16, 2009
JBnID
  • 243 Answers
SOURCE: Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Posted on Aug 07, 2009
Cecilware fms40 fryer convert to lp gas
Most NatGas devices will convert to use of LP by changing the orifice.
GRINDMASTER CECILWARE F177A ORIFICE 52 1 16 LP GAS
Oct 05, 2015 | Cecilware FMS-40 Deep Fryer
Looking for the manual, also want to change from LP to NG. Need instructions for same.
To change from lp to Ng the change required is different jets in the burners Nothing more
go to a shop that sells gas cookers. B B Qs and they will have the jets in stock
ask as to adjust the air shroud to keep the air mixture right
Apr 12, 2015 | Grilling
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
I have purchase 2 used FMP 40BSS fryers - originally Nat Gas - i want to convert them to LP - what is needed and can i do it myself?
To convert these to LP you must downsize the burner orifices and the pilot orifice. Also you must change the regulator on the gas valve to LP. Easy job.
Tom
Aug 14, 2010 | Cecilware FMP40BSS Deep Fryer
With the Jenn-Air PRG4810NP (Natural Gas), is there any way this can be converted to LP with a regulator? I'm not sure if I ordered the regulator for the LP range and attached it to the NG model, if this...
Conversion is usually accomplished by flipping the regulator cap around. Nat side is hollow and LP is solid to hold the regulator open. The oven orifices are adjustable and the surface burnres can be either adjustable or have LP replacements.
Eric
Jul 01, 2009 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
