Question about Uniden Cordless Phone
No dial tone on uniden 5.8GHz digital phone
Sounds like maybe it's on intercom. Lost the manual. How do I get back the dial tone?
  • bkpd Apr 02, 2009
    Same thing. Phone sounds like it's on intercom and will not accept calls or let me make any calls. Tried everything I can think of to no avail
There is no dial tone on my land line uniden 5.8 ghz.
Posted on Mar 26, 2009
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
Why will my uniden phones not dial out, all units will not dial out. Phone jack works, but when I try to dial, with each digit pressed I only get a dial tone. Phone will receive calls, but I cannot dial...
I have not seen this in a long time. 'Way back in
the 1970's a similar problem would occur when the
telephone company accidently reversed the 'tip and
ring' wires.
This was only a problem with the
then-new "push button" (tone) dialing, the standad
rotary dials worked fine. The fix was to reverse
the red & green station wires in the "B-block"
(on the baseboard) to undo the central office goof.
Maybe it still happens? Try reversing the red &
green wires in the modular socket you are plugging
the base ('main unit') into.
Feb 18, 2015 | Uniden Cordless Phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How to get phone back to tone dial instead of pulse dial
Since you declined to specify the model of your Uniden cordless phone, I can only suggest you select it from the list beginning here to download a copy of the manual. The manual will explain how to switch between tone and pulse dialing.
Jan 19, 2011 | Uniden Cordless Phone
How do I turn off my ringer on my Uniden 5,8ghz expandable cordless phone system
Since you declined to specify the model of your Uniden phone, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
Jan 08, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
KXTD816 Panasonic telephone - lost phone connection
Good thing. You probably don't need to know. Try powering the system down, and power it back up. Watch the lights as it comes up.
Do you get a solid light on the lower right side of the cabinet? Now see if you can dial intercom to intercom calls. Press one of the line buttons and see if it lights up. If it does, I'd be looking for dial tone at the telco interface. Those are RJ-14 jacks (2 lines per plug).
P.S. The reset button you don't want to press is on the lower right side of the cabinet. If the switch is in the wrong place, you'll trash the memory.
May 31, 2010 | Panasonic Lands Phones
Lost manual
How do I change phone from pulse dialing to tone dial.
Thanks
Rjfawcett52@yahoo.com
Apr 22, 2009 | Uniden Cordless Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
We need a manual for cordless phones - lost ours
Here is a link to the GE website with manuals. I found 5922 EE1 and EE2. I wasn't able to find FE2, but I bet that one of the 5922 manuals will probably help...
http://www.home-electronics.net/ge/pc/user-manuals.asp
Dec 28, 2008 | Uniden Cordless Phone
UNIDEN POWER MAX 2.4 GHZ
Do you have the manual on line for the Uniden PowerMax 2.4 GHZ
Apr 01, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
680 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
