Question about Electronics - Others
I have i cassette tape tc-20 i need adapter to put in my vhs recorder
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Have to reassemble VHS-C cassette
Tried searching for a diagram but didn't find one. Usually the spring goes to the plastic door protecting the tape. If the door isn't retacting, you should remove the door altogether and the tape should work as long as it is moving properly when you turn the take up roller on the tape by hand.
Posted on Dec 10, 2008
tbreeze47
  • 3083 Answers
SOURCE: I inserted a vhs-c tape in to my cassette adaptor
That may be what you will have to do, in this case, unless you can somehow get that switch to work. I don't understand why the motor continues to run, but it's probably a broken plastic piece or other gear part that's not functioning. When you take the cassette apart, try to look for any broken parts, or loose components that you can reseat. You may have to end up buying another adapter. Wish I knew more to tell you, but that's all I can think of.
Posted on Apr 18, 2010
SOURCE: JVC VHS Cassette adapter C-P7u
How to safely open Micro MC_90 cassette
Posted on Oct 19, 2010
SOURCE: My vhs c tape is stuck inside my vhs adapter... It
My vhs c tape is stuck inside my vhs adapter and changing batteries does not help. Is there a way to manually eject it?
Posted on Dec 24, 2010
Schematic needed to fix machine that rejects tapes
Mode selectswitch first in high priority to clean important cleaning is the first thing by the Philips g110 running mechanism if its not function well.
Everything is timed from put tape in and eject . by selectswitch
20 years ago was it top to repair videos like this . G110 chassis .blaupunkt Grundig Philips Hitachi and Panasonic are made by very little marketing technical differences in the parts beware of that . but just the same kind of VHS recorder .
Service Manual free download schematics datasheets eeprom bins pcb repair...
Jan 19, 2016 | Panasonic Ag-1970 S-vhs Video Cassette...
8mm JVC tapes put into a VHS tape that will play on a combined TV and VCR. Please, please, I need your help! Found tapes from 15 years ago.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Jan 08, 2015 | JVC P-6120JDU Video Cassette, 8mm 120...
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
Found many family TXK E-HG TC-20 tapes. What device do I need to see these?
The TC encoding usually stood for VHS-C type of tapes. These were created so that VHS type manufacturers could compete with the HI-8 type of camcorders that came out years ago. They were essentially regular VHS tapes that were shrunk down in size to allow them to build smaller camcorders.You could either play them back directly from the camera itself, or you could use the adapter that came with the camera that allowed you to play the tape back from a regular VHS VCR. The adapter was the size of a regular VHS tape, and it had a lid on the top that you would open and drop your VHS-C tape into it.
If you still have a VHS VCR you could watch the tapes using an adapter. If you do not have one you can search on the web for both the adapter and a VHS VCR if need be. Depending on the size of the city you live in there may be a conversion outfit that can take your VHS-C tapes and burn them onto DVD's for you. Prices varied quite a bit on that service so you should do a little shopping around if that is the way you want to go.
Jun 27, 2011 | Cameras
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Many years ago some one told me that you could put your canon video camera 8 mm tapes into a video cassete case and play them on vhs tape machine is this true cause i have many but can not get whats on...
Hello, try matelectronics.com, they have the following product, I think it's what you're looking for: VHS-C CASSETTE ADAPTER(Reference #V-0730)
VHS-C CASSETTE ADAPTER BY PHILIPS PH61300
Jul 20, 2010 | Sony Televison & Video
Dec 10, 2008 | TDK TC-30HG VHS-C Tape
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
