Question about Peak Performance Peak PKC0AJ03 400W Power Inverter
Where is the internal fuse on Peak 400 watt inverter
2 Suggested Answers
  • 19 Answers
SOURCE: does peak 100 watt inverter have a fuse inside? It
yes it does have a fuse inside where you plug it in the lighter should have a metel tip on the end will be spring and fuse inside behind metal tip
Posted on Jul 04, 2011
Why do the fuses blow out every time I plug it in
watts divided by volts equal amps so 400watts devided by 12 volts equal 33 plus amps if wires and fuses wont handle 35 amps they will blow to keep from burning up the wiring of your vehicle
May 14, 2015 | PEAK 400 Watt Tailgate Inverter Max -...
What is the amp size of the external fuse of a whistler 400 watt power inverter
The lighter socket power cord has a 15 amp fuse. The cable with the battery clamps do not have fuse protection.
Aug 27, 2012 | Whistler 400-Watt Power Inverter - Silver
Does peak 100 watt inverter have a fuse inside? It is brand new & i can't make it active.
Jul 04, 2011 | Peak Performance Peak PKC0AM 100 Watt...
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
What size fuse goes in this item
The fuse you wilkl need to p-0rotect this unit is rated at 50amps
Please rate my help++++Thanks for using FIXYA
May 27, 2010 | Peak Performance Peak PKC0AM 100 Watt...
Power drop
Hey, Question: Is the 2400 watt the peak rating or the continuous rating of the unit, and what is your power source for the inverter. If 2400 is the peak, the 1200 is probably the continuous. Your 75 watt fridge will draw probably 150-170 watts to start up, which will load the inverter to draw 15-17 amps of load on your 12 volt power source. If the battery supply is weak, the current draw at startup will cause the voltage to drop and set off the alarm. Getting the start up out of order may work for a while, but will eventually blow the internal fuses on the inverter, or possibly blow out the capacitors. Check the condition of the battery supply, and make sure the bar fridge is in good working order to resolve this problem.
Jul 18, 2009 | RoadPro RPPI-2500W Inverter
Does item have a fuse? Burned out
i have the same one ...and i'm not seeing a fuse, there may be one internally
does the inverter have strong "burnt wire" smell if so it is probably fried.
Aug 16, 2008 | Vector VEC 024 400-Watt Power Inverter...
Peak Performance Peak PKC0AJ03 400W Power Inverter Logo
35 people viewed this question
Top Peak Performance Electronics - Others Experts
Are you a Peak Performance Electronics - Other Expert? Answer questions, earn points and help others
