Question about Dell Mini 910 Netbook
My bootmgr is copressed.
I compressed some files to save space and compressed the bootmgr. where do i go from here?
  • Dell Master
  • 27,725 Answers
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot. or The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk. When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready.. w7 insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
it will work 100% only if you prompt at the same order Hope this helps. BOOTMGR Is Compressed b> The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Posted on Jan 15, 2013
If TFGHT is compressed, can i reformat my laptop without cd? or pressing long 0. give me an answer. please! :
Saving space by compressing the drive is not a good thing.
What follows applies to both 32- and 64-bit Windows Vista and Windows 7.
The tip off that the Windows drive has been compressed is a message which looks like the following. 'Some file' in the message can be anything. It might be BootMgr, TFGHT, QXHDK, DFJEU, VUFEI, DGKAR,..
'Some file' is compressed. Press CTRL+ALT+DEL to restart.
Windows will not start.
1. The first step to fixing this is to begin the process which leads to the Windows Recovery Environment (aka WinRE). In both Vista and W7, one can use an installation DVD if available. In many OEM environments (including Toshiba's), one can use the entry Repair Your Computer on the F8 Advanced Boot Options menu. In Windows 7, one can use a System Repair disc.
2. On the way to WinRE, you will encounter a screen that looks like this.
3. Click the Load Drivers button and you will find yourself looking at folders on your computer..
4. Find Computer on the left side (the navigation pane) and left-click it.
5. On the right side, right-click the drive with Windows (the C drive) and click Properties in the pop-up.
6. At the bottom of the Properties box, clear the check box that says Compress this drive to save disk space.
7. Another window will pop up asking you to confirm the change. The windows will get messy at this point. You'll need to move them around the screen to see things. Don't panic.
8. On the new window, set Apply changes to drive C:\, subfolders and files, and then click OK.
9. Now you'll need to wait for a few minutes while the decompression takes place. You won't see a progress indicator.
10. After your hard disk stops showing activity, cancel the remaining boxes and restart the computer. It should boot normally.
Nov 16, 2015 | Toshiba Computers & Internet
What does the positions High,Medium. and Low on photo mode mean?
Without knowing the make and model of the camera this is only a guess, but I would say it's either the image quality or image compression for the JPEG files.
Just about every camera stores photos as JPEG files (many cameras also offer other options, but JPEG is almost universal). JPEG uses a lossy compression scheme. This means that files are compressed to save space on your memory card. This compression throws away some data. Usually this is not noticeable. For example, if one point of a blue sky comes out a different shade of blue (but still close to its neighbors). It would be noticeable if a patch of sky came out green, however.
High image quality applies minimal compression, at the expense of file size. Low image quality applies more compression, saving file space but sacrificing quality.
Compression is the other way around. High compression saves file space at the expense of quality. Low compression gives higher quality at the expense of file space.
Whether these settings on your camera determine the image quality or the image compression, I can't say. You'll have to look in the manual for your camera.
If you require further assistance, please add a comment to this question and specify the make and model of your camera.
Nov 07, 2014 | Cameras
I compressed files for more space,now i can' reboot to windows.My screen says,Bootmgr is compressed(press ctrl+alt+del to restart but nothing happens.keeps booting back to that screen.Please help!
When the computers is booting up try pressing f8 till you get to a black screen and click last known good configuration... This should help.... Or else you'll need to install the operating system again
Nov 22, 2013 | Dell Precision M90 Notebook
BOOTMGR is compressed says Press Ctrl+Alt+Del to restart. Keep going back to same thing.
Your MBR (Master Boot Record) is probably corrupted.
You could use Google to find a way how to repair the MBR for your specific OS
Bootmgr compressed
Check this discussion out - specifically moti68's comments. Good luck!
http://www.howtogeek.com/forum/topic/bootmgr-is-compressed
Jan 15, 2013 | Dell Mini 910 Netbook
Boot manager compreessed
Sadly the startup repair option or any other repair option in windows 7 startup recovery failed to solve this problem. this can be solved by
reboot your pc
select the repair your computer option
command prompt
at the prompt type notepad (since the recovery option boots from a seperate wim image it has notepad built into it )
press ctrl + o which invokes the open file dialog
go to the open file field (ALT+N) and type c:\boot and also see for the c:\bootmgr
file. right click it and deselect the option of "compress files to save disk space"
when we apply the boot manager is again decompressed. also if someone finds this harder we can directly deselect the compression option by reversing the process used to compress the drive
thats it . we are done
Apr 16, 2011 | Computers & Internet
"BootMGR compressed "how to boot the system
Hello;
  • Insert the installation DVD in your system and start the pc above.
  • Click Repair your computer.
  • Then click on Load Driver.
  • Go to Computer.
  • Right click on the partition your installation previously compressed> Properties.
  • Then uncheck "Compress drive to increase space available".
  • Then close all windows to restart the computer.
Nov 02, 2010 | Acer Aspire One PC Notebook
Boot manager is compressed
Go ahead and try to restore your Operating Systerm with whatever disks the manufacturer came with the computer. As an aside though, the need to compress a drive with multiple gigs of space anyway ... overkill? If you do not have the disk, use any OS startup, XP/Vista/Win7/ whatever OS you prefer. You did not state the HD size, but the compression (and consequent uncompression) will slightly slow down processing after all is done. Good Luck !!! More questions, jaye.ellen@gmail.com
Apr 21, 2010 | Gateway MX6959 Notebook
BOOTMGR is compressed press Ctrl+Alt+Del to restart
Insert Microsoft Windows Vista Installation Disc.
Press any key when it says "Press any key to boot from CD".
After that you should see "Windows is loading files..."
KEEP pressing F8/F9(can't rmb which, just press both alternately) while
the progress bar loads..... Dun let go until you reach "Advanced boot
information" where you should see Safe Mode, Safe Mode with Networking,
Last Good known configuration etc...., just select Safe Mode with
Networking(or Safe Mode/Safe Mode with Command Prompt) and press Enter.
Wait for the files to load and there should be "Safe Mode" on 4 corners
of your monitor.
Just be patient and wait. A windows would soon pop up and says "Install
Windows". Don't worry, click next. Now at the bottom of this window, you
should see "Repair Windows". Click on it, and there are several options
available here. For this case, which is "Bootmgr is compressed.", CHOOSE
THE LAST OPTION - "Start Command Prompt".
OK type these things (Only works if you have Firefox, can't think of
anything else) below and follow closely:
When Command Prompt is started, type the command below first to ensure
that C Drive or whichever drive which contains all your system files is
selected:
LOOK FIRST!
X:System> (The string on the left is what appears on command prompt,
may differ on other computers.)
Now TYPE "C:" or "D:", depending on the hard disc volume you are
using...
SO IT BECOMES:
X:System>C:
PRESS ENTER
THE RETURNING COMMAND WOULD BE:
C:>
If you get this, very good, continue with the steps below.
Now Type:
CDProgram FilesMozilla Firefox
PRESS ENTER
THE RESULT SHOULD BE SOMETHING LIKE THIS:
C:>CDProgram FilesMozilla Firefox (Press ENTER)
C:Program FilesMozilla Firefox (<<<<< Result)
Now type "firefox".
wait for Firefox to launch now.
it doesn't matter if no internet is available.
Now on firefox, go to File > Open File
Double click "My Computer", and you should see your hard disc there,
but don't double click on the hard disc. Instead, click once on the hard
disc, RIGHT CLICK, and choose properties. AT THE BOTTOM, UNTICK, I
REPEAT, UNTICK THE BOX SAYING "Compress this drive to save space
etc....". NOW CLICK APPLY, WAIT, AND I MEAN WAIT PATIENTLY OK? AFTER
THAT CLICK ON "OK".
AFTER PRESSING OK, DO A QUICK LOOK AT YOUR DRIVE BY DOUBLE-CLICKING IT
NOW. IF ANY FILES/FOLDERS ARE BLUE IN COLOUR INSTEAD OF BLACK,
RIGHT-CLICK IT, CHOOSE PROPERTIES, CLICK ADVANCED BUTTON (Beside
Read-Only Box and Archive Box), UNTICK, I REPEAT, UNTICK the 3RD BOX
Which says "Compress contents to save disc space".
Click OK, Apply and close the folder/file properties.
Now close the box opened by firefox, close firefox, close command
prompt AND AT THE BOTTOM RIGHT OF THE FIRST WINDOW WHICH POPS UP
MENTIONED EARLIER, PRESS RESTART.
for xp:
Boot Manager is compressed
If by accident having compressed the entire boot partition, then Vista will display the following error:
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
Check points for fixing compressed boot-manager:
* Boot into Windows Recovery Environment (WinRE) and perform a “Startup Repair”.
* If the above doesn’t solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press “Load Drivers” (Instead of “Next”) and use the mini Windows Explorer to right-click the boot-drive and deselect “Compress this Drive” and choose Apply to sub-folders and files.
* If that also fails then boot into WinRE again, and go to the “Command Prompt” and execute these commands:
o compact /U C:ootmgr
o compact /U C: tldr
Mar 30, 2010 | Compaq Presario 700 470024-192 Notebook
Help my toshiba showing me bootmgr is compressed
Hello.
Your system files are corrupted.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
Dec 13, 2009 | Toshiba Satellite P205D-S7438 Notebook
Dell Mini 910 Netbook Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
