Question about Water Heaters
Whirlpool e1f30ld035v will not hear continually - trips breaker
3 Suggested Answers
  • 34 Answers
SOURCE: NEED PART # FOR ANODE ROD.
most anode rods are universal and can be bought in any large hardware store or plumbers wholesalers. Take your along to be sure, just make sure you shut off the water first and drain the tank.
Posted on Jun 26, 2010
SOURCE: Breaker trips; reset breaker at
For many years electric water heaters were wired with #10 wire with a 30A breaker, as water heated technology improved in the 1990's water heaters did not NECESSARILY need to be on a 30A breaker anymore, many electricians began to install #12 wire and a 20A breaker, during normal operation the water heater drew 17A, as the water heater collected sediment over time the current draw increases and may trip a 20A breaker, I would suggest checking the wire and breaker combination and if it is #12 and 20A, you may have to upgrade to #10 and 30A
Posted on Oct 02, 2011
Keeps tripping the breaker
Breaker keeps tripping means short in wire or heat element
Shut power off . use ohm meter and go from ground to each wire on elements and if you get continuity. there is short pull wire off element check wires to ground not continuity bad element.
still shorted follow all wires may have bare wire shorted against cabinet Or by new heater
Jul 02, 2015 | Water Heaters
Newly installed Hott Rod in 6 gal RV water heater only heats to lukewarm. Has been on for 12 hours. Outside temperature is 60 degrees
Hott rod is 120Volt AC.
Check voltage supply for undervoltage, or reversed polarity, or tripped breaker.
Check that electric thermostat is set to 120 degrees.
Rotate thermostat temperature adjustment back and forth and see if you can hear water heater working.
Thermostats can be bad, or stick.
Check the ECO red reset button is not tripped out.
If tank was not full of water before power was applied, the element will instantly burn out.
Use continuity tester across bare element screws to see if element is good. Or use multimeter and test across bare element screws shows 29 ohm for 6 gallon, 18 ohms for 10 gallon.
More resources at Hott Rod, for troubleshoot and contact.
http://www.hottrod.net/hott_rod_troubleshooting.asp
Oct 31, 2012 | Camco Hott Rod RV/Camper 6 Gallon Water...
I have a Rheem 82vs50-2. Can this heater's elements be wired continuous for 9.0kw and is there any mfr documention that allows continuous wiring of this heater
You have dual element 240Volt tank-type electric water heater.
You want to change wiring from non-simultaneous to simultaneous.
Copy following link for exact internal wiring diagram, and external wiring change: Remember the wire from breaker box will not support both elements without tripping breaker, so you will need additional 30 amp breaker and 10 gauge wire, or single 50 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
http://waterheatertimer.org/Color-codewire2.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Sep 23, 2012 | Rheem Water Heaters
The water heater breaker keeps tripping and I have to reset it to get hot water. It continues to be a problem, what should I do?
Thermostat could be bad causing the breaker to trip due to it being shorted. It's either your breaker or the thermostat, more than likely the upper thermostat is bad.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
Breaker trips; reset breaker at panel and water heater "on" light comes on. Breaker tripped again in 5 min; reset breaker again and water heater light comes on. Cycle continues to repeat. Bad...
It is possible that the breaker is bad. It is also possible that your water heater is overloading the breaker. It is probably easier to try a new breaker to start with. Unless you are familiar with changing the breaker, call an electrician. Your life is a very valuable asset to you!
Feb 18, 2011 | Water Heaters
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
I just replaced my old rusted out water heater with a new Reliance 606 and now I am having problems with the circuit breaker being tripped, usually during the night. It doesn't happen everyday but is...
I would check with your owners manual to see what they reccomend for minimum breaker size. I don't remember on this particular model but it may be a single element instead of dual element. The single element usually use more power than dual. I would also check thermostat settings if this is a dual element. They should never be set at same temperature. Also if it continues to trip breaker I would check all wiring,then replace breaker. Sometimes they do wear out and trip when they really shoul not. Hope this helps. Thanks
Nov 15, 2010 | RELIANCE ELECTRIC WATER HEATER
Hello, i have a reliance 606 im having a problem that the reset button, it keep on tripping. when i reset it last like 2 days then it trips again. i have changed the upper thermostat and element and it...
It sounds like you have things pretty well covered. I would change reset and if it continues to trip breaker I would check wiring very carefully where it enters top of water heater. Check for any nicks or bare spots on wiring insulation. Other than that about all I can think of is to change breaker. Sometimes they do get weak and trip to easily. Hope this helps. Thanks
Nov 10, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
88 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
