Question about Maytag Neptune MDE5500AY Electric Dryer
Felt belt hanging above dryer door
About a week ago I opened up the dryer box (removed door assembly) to vacuum out any build up of lint. Now I have a grey felt strip about 2 inches across dangling in the doorway and emerging all around the top edge of the drum. Now do I need to buy a part or is this something that I caused by vacuuming out the interior. Is it something that is usuallly wedged in place or has broken or lost its stick-um? Thanks for any words of wisdom.
  • Joe Lukert Jul 09, 2007
    Ok I went to a parts site and found felt drum seals ranging from $10 to 25 and $10 for the high temperature adhesive also found cylinder felt seals. I thought remove door, repostition felt and maybe glue if needed. Now what is a partial machine strip down? That sounds like I am over my head and need to call the guy in the blue jumpsuit. My lint fire hazard worry seems to have just caused problems and there was neligible lint after almost 3 years anyway.
A few screws and locking clips and the whole front will come off, is that what you mean by a "partial machine strip down"? I took off the front to vaccum out lint that was not there and later found the felt strip was out partially. My old dryers would fill up in the box so I thought I would have to routinely clean this one, oops I created my own problem I think. Thanks for both lightning responses and it is back to the dryer for me as I think you have SOLVED my problem.
Posted on Jul 11, 2007
    Sergeant:
  • 236 Answers
It sounds like the front drum seal, this is what the drum runs on and seals the surround for fluff ingress. if it is hanging down then it is damaged and will need replacing which will be a partial machine stripdown.
Posted on Jul 09, 2007
  • tony howlett Jul 10, 2007
    if there is not much lint got through you may have found the problem quickly. if you feel you can pull the door opening forward enough to replace the seal then certainly try it, the only reason we strip it down further is to guarantee a good and lasting repair, tony.
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Oct 02, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do I take the cabinet off a GE gas dryer model # DHDSR46GE1WW to check inside?
The following website may be helpful:
https://www.partselect.ca/Models/DHDSR46GE1WW/Instructions/?InstructionID=21302
This was extracted from the website:
Remove the two screws at the front above the drum opening (with the dryer door open). The top panel then lifts off. I removed the screw at each side that holds the front panel to the side panels, tilted the front panel forward, which disengages the front of the drum from the front drum glide bearing. I then lifted the front panel slightly, unhooking the bottom of the panel from the dryer base, and swung the front panel aside.
Oct 10, 2017 | Dryers
I have a Kenmore Dryer (electric) which is almost 30 years old. Recently it simply stops after a few minutes sometimes 2 sometimes 15. In the past, I have had to tighten hinges on the door. But the...
inspect the door switch to make sure it is seated properly, as it sounds as though it is no longer locked in place and the vibrations of the dryer tumbling is causing it to break contact thus shutting off the dryer. Hope this helped Tim
Jun 07, 2011 | Kenmore Dryers
Runs for a while than shuts off if i take the back off it doesn't shut off.
Usualy this is caused by poor airflow through your dryer. Remove the lint filter and check for a lint build-up near the bottom of your lint filter. If you see a lint build up use a vacuum crevice tool and something long like a fly swatter to loosen the lint as you vacuum. Also check the dryer vent tubing and the outside vent flapper for obstructions. What is happening is your dryer is heating up until the high temp limit protection rhermostat shuts off the heating element.
What I just mentioned is apparently not your problem. You said that your dryer runs then shuts off completely. Check to see if the motor is easily roated by hand with the belt installed. If it is difficult to rotate there is a bearing problem somewhere causing heat to build up in your motor until the thermal overload shuts off the motor. There is a drive belt idler near the motor that can also cause excessive drag on the belt if the bearing has failed. The last thing to check would be the drum rollers located in the groved area on the outside of the rear of your dryer drum. If these have stopped turning they act like a drum brake and can also cause the same symptoms. Removing the back panel allows the chassis to shift enough for the drum to ride lighter on the drum roller even though it may not be turing it is enough for the dryer drum to skid / slide on top of the stuck drum roller yet not shut off.. Hope this helps and good luck. I can help with access issues need be here.
One question I have is does your dryer door open and close properly? Some times a bad door seal or door catch can cause the same symptoms. Open and close the door and losten for a switch click as the door opens or closes not far from the closed position.
Jan 06, 2010 | Kenmore 62602 Electric Dryer
How to instruction on replacing felt gasket in the
easy, get some high temp adhesive before opening up.
then if lint screen on top, remove screws under cover, pull top forward and lift. it hinges in rear. remove 2 screws on front holding front panel to cabinet sides. disco door sw and lift front panel up to remove. undo belt from motor , note setup with spring roller.
if lint screen in door, remove contrl console, screws under end caps(pop off frame end caps from top). remove screws at rear of top holding it to rear panel. and slide forward. to remove. remove lower kick panel (use putty knife, hidden clips in seam), remove screws holding air duct to blower housing, disco wires to moisture bars at connector. remove screws holding front panel to cabinet, then at top and remove panel remove springs if necessary. pull tensioner away from belt and remove belt.
lift drum up and out. note gasket flange orientation and pull off. clean and sand off old as well as possible and apply glue to drum as you apply new gasket, it will be tight at end.
Apr 27, 2009 | Kenmore 63942 Dryer
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the back?
Dryers do not open from the back
the screws removed secure parts to the inside of the case
carefully replace them.
to opent the front of the dryer
unplg dryer
type I: maytag:kenmore stackable:speedqueen:
  • remove 2 screws from bottom of front panel, swing front panel out at bottom and unhook from dop
  • remove door switch wires from switch
  • remove front panel set aside
type II: Kenmore:whirlpool:ge:frigidaire
  • remove lint filter
  • remove 2 screws in lint filter holder
  • with putty knife or other blunt blade
    depress spring catches at corners of top cover
  • lift top cover at front
  • remove 1screw each side 1/3 way down
dryer internals are exposed and easily repairable
examine back panel to ensure that nothing is detached from screw removal
assemble in reverse order
Note:
while the dryer is disassembled, examine felts rollers and glides for wear, most common cause of belt breakage, if there is any wear, replace.
examine fan, fan housing and ducting for lint that got past the filter screen.
Oct 28, 2008 | Dryers
Drum bearing
most dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • unpug dryer
  • remove screws from bottom bend of front panel
  • lift front panel off
  • sent front panel aside
pull tensioner pully off bellt
pull belt off motor pulley
pull drum out forward
felts installed on drum edges can be examined for wear, as should roller support bearings
reassemble in reverse order
Different dryers may have: nylon glide plates, felt bearings rubber tired roller bearings or any combination of the above.
Local parts guy will have the parts as they are common to many dryer models.
Sep 06, 2008 | Dryers
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • raise case lid
maytag
  • remove doo switch cable
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Heating element
IF you have the dryer pictured above,
You'll have to remove the console (screws behind covers on endcaps.) Then flip the console up and remove three screws holding the top panel down. Slide the top panel toward you and remove. Disconnect light and door switches (top front left.) Remove the toe panel (putty knife on two tabs top left and right.) Open the door and remove the lint screen. Close the door and remove the metal triangular box around the lint screen. Remove the screws at each corner of the front panel. Lift and rotate the front panel slightly clockwise to get the basket off the rollers. Reach under the basket to disconnect the belt from the motor. Lift the belt and the basket out of the machine. You can now reach the heater on the bottom left.
Before you do anything, unplug the machine, remove the lint screen, toe panel, and metal box and check the white plastic thermal fuse on top of the blower housing with an ohm meter. It should read less than one ohm.
Mar 09, 2008 | Kenmore 63942 Dryer
DLG5988W Gas dryer
you might want to check you venting, if tis not clear, your lint might be building up inside machine and burning off as you use your unit.
Mar 01, 2008 | LG DLG5932W Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
397 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
