Question about Bell CoPilot Model "A" Jogging Stroller and Bike Trailer
Can i wash copilot bike trailer in washing machine
Have a lhw0050pq4 ft loader washer (whirlpool) 5 years old little use. in 5th wheel trailer and it seems to lose its place in the cycle can you help?
The control board will need to be replaced. It is located on the top, right hand side of the unit as you look at it from the front. Remove the screws on the top panel, slide it back to remove it. You will see the board. Here is the board to order.
Oct 29, 2012 | Whirlpool LHW0050PQ Front Load Washer
Tip
Change the belt of a washing machine
It may happen that you have to reassemble a washing machine belt (belt is being broken or simply withdrawn from its normal location).<br /> With a change thinking about ordering the same belt model.<br /> The mounting is done of a bike chain:<br /> -Placer the belt on the motor axis and a part on the pulley.<br />loyalty turn the pulley.<br />-the belt will be implemented alone.<br /> <br /><img src="nidalkom01_11.jpg" />
on Jan 10, 2011 | Washing Machines
I live in a trailer home and my dryer runs but doesn't heat up I was told it was do to my trailer grounding I have 1 ground hooked to my breaker box and none directly to the trailer it's self should I...
No. If you have properly installed 220 volt electrical service all outlet and load center grounds should be isolated from the trailer and only go to ground at the main box. it is not a perfect world though, so I would not take it for granted. if the dryer has never gotten hot where you live now, a professional electrician is the only way to go.if it worked and one day stopped, suspect the heating element. remember please, 220 can kill you easy and can even jump quite a distance if conditions are right
Feb 28, 2010 | Washing Machines
Should we buy a front load washing machine if we live in a mobile home? We heard that when it spins it will shake our trailer to pieces. Is this true?
If your trailer is frail enough to fall to be in danger of falling to pieces with the vibrations of a front loader--which are steady but not violent--you'd likely be better off to pick up a used top loader from Craigslist for $50 and put the money you save into structural repairs or a security deposit on a solid dwelling.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
I just rented a trailer, and they only have cold water hookup.
yes it must be capped, you can find one at any hardware store.
Oct 17, 2009 | Maytag Performa PAV2200
Washing machine repair
you have a bad motor coupling( this machines equivelen to a belt) part number 285753. you can search you tube for a videio on hoe to acess the motor coulpling, easy enough repair so long as you have basic mech. skills and tools need onlya phillips, regular slotted screw driver a,d perhaps a 1/4in nutdriver/socket
Oct 30, 2008 | Kenmore Washing Machines
Bell CoPilot Model "A" Jogging Stroller and Bike Trailer Logo
22 people viewed this question
Top Bell Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Bell Baby Gear Expert? Answer questions, earn points and help others
