Question about Garmin GPS
Showing wrong route - Garmin GPS
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
Adjust belt tension
Ypur Ford has a self adjusting (non-adjustable) belt tensioner. If the belt is from 2008, you wouldn't go wrong replacing it. However, if it is really loose, either your tensioner spring has crapped out or the belt has been routed incorrectly. A diagram under your hood should show the proper routing of the belt. Good luck.
Apr 22, 2014 | 2008 Ford Fusion
Belt routing diagrams
Hello-
According to Dayco, this is it. Give a quick holler if this doesn't make sense, sometimes they get it wrong. Engine code is always nice to make sure.
Fig. Accessory drive belt routing -3.6L engine .
Fig. Accessory drive belt routing -3.8L engine
Apr 02, 2014 | 2006 Buick Lucerne
I think i routed my serpentine belt wrong i need a really clear routing diagram for a 2004 grand prix
usually somewhere under the hood you will find a diagram showing how your belt should go. If not ask your local discount auto parts store and they can help you.
Aug 17, 2012 | 2004 Pontiac Grand Prix
Triton 400 sometimes street maps move anywhere from 100 ft either way to 1/8 mile away from route and makes it show you are off road or in wrong lane.
This problem is most caused by two possible errors. One the maps were not prepared correctly.
Two your navigation settings are wrong. Please reset the datum to WGS84 and see if this helsp.
Nov 09, 2010 | Magellan Triton 400 Handheld GPS Receiver
I have a 3com 4500 connected to 2 5500s (A & B), which are the the GWs for the 4500. I issued on the 4500: ip route-static 0.0.0.0 0 192.168.0.254 preference 60 (5500 A) ip route-static 0.0.0.0 0...
From your scenario what i guess is the two 5500's (A&B) are connected to each other also. Thats why the link between B&4500 is remaining down due to STP ( to avoid Network loop).
Please correct me if I am wrong.
What is the status of the link connecting 4500 to 5500 B when 500A is active and when 5500A is down .
If you are running STP i will suggest you to wait for 2 minutes after 5500A goes down and STP will be recalculated and the link connecting to 5500B will become active and then the route will also become active.
Best regards
Nov 02, 2010 | 3Com 4500 24-Port Ethernet Switch
The distance for the trip in my favorite is wrong.
Sounds like you might have "off road" selected for your navigation preference. Shortest distance between 2 points is a straight line, or great circle for GPS units. As the crow flies will be shorter than a road route.
Jul 04, 2010 | Garmin nuvi 205W GPS Receiver
I replaced the tensioner and serpentine belt is too loose
if the tensioner is on right and the belt is the same size as the old one you have it routed the wrong way. there should be a label under the hood or on the radiator support that shows routing. let me know if you find it.
Dec 13, 2009 | 2000 Dodge Durango
Serpentine belt diagram for a dodge durango 1999
hey go here and look at picture 7-20
http://www.daycoproducts.com/daycoweb.nsf/Serp%20Rout%20Guide%20Illus.pdf
Jan 07, 2009 | 1997 Dodge Ram 1500 Club Cab
Confused satelite signals
Make sure GPS has clear view of sky.
Jan 04, 2009 | Garmin GPS
GPS Logo
16 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
