Error code 0xc19a002 and error code 0xc18a0106
SOURCE: HP Photosmart d7368
Here is the document that i want you to follow correctly inorder to solve your issue.
CLICK HERE TO VIEW==>> DOCUMENT
Please let me know the outcome after following the document.
Thank you so much.
adonscott
SOURCE: On Photosmart D7260 display shows
I have theHP photosmartd7260. I am getting an error code - oxc18a0001 - ink system has failed - unable to print
SOURCE: Photosmart D7260 does not sense Paper in maintray
I had the same problem. I hadn't used the printer in a long time and it took a few minutes to figure out what I did. This may not be your problem, but there are two sliders on the main tray. The first goes left to right and the second goes front to back. If you've use normal 4x6 paper you put the paper in and push the slider forward to lock in the paper so it prints straight. The problem is if you run out of paper and haven't used the printer in a long time, you may try to slide the paper in just like you would a normal printer. But for it to work, you have to pull the front-to-back slider back, and make sure the paper is forward of that slider. If you've pushed it way forward after trying to shove your paper in, you may have to find something to pull it back out again, because your fingers might not be able to get in that far.
SOURCE: The screen no longer works on the hp photosmart
the touch screen on my hp is showing only black. it has a orange exclamation flashing and the manuel only says there is a error if you see this exclamation, Helpful!! I tryed to unplug everything and restart, didn't work still black and not working. any thoughts?
