Question about Nextbook Tablets & eReaders
I have the Sharper Image m18a android tablet and everytime i touch the screen there comes some blue cross that draws a short line and there are some columns in the top of the screen conected to that i
This has just recently popped up and is very strange and annoying and i can't find on the internet any guidance to make it go away. Every time the screen is touched the blue cross comes on and draws a line that follows your finger and doesn't disappear until you touch the screen again. The columns in the top of the screen are grey or sometimes red, they are connected to the blue cross because its like they're showing it's position. Please help.
In my tablet, in settings, under 'Developer Options' in 'User Interface' there is 'Pointer Location' which is a screen overlay which shows current touch data. To me what you are seeing sounds exactly like this function when it is selected. Hope this is the answer you need.
Posted on Jul 04, 2013
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Posted on Dec 09, 2008
anjana03
  • 361 Answers
SOURCE: Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
Posted on Jun 13, 2009
SOURCE: touch screen and digital finger scan's not working
there is one option that you have tak back-up your data then run recovery disk that is only solution becoz touch screen and finger print software is realy delicate things dont try to paly with if don't have to downlod drivers from the HP site
Posted on May 14, 2010
  • 56 Answers
SOURCE: HP Tablet TC 4200 without
It will need the pen to work.
Posted on Mar 23, 2011
  • 14 Answers
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Posted on Apr 08, 2011
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Proscan 7 inch tablet keeps freezing
My proscan tablet is keep freezing and lines are coming across the screen. What can I do
Dec 28, 2013 | Proscan 7-Inch Android Internet Tablet,...
Refacciones para tablet sharper image 9
donde puedo conseguir el display touch para una tablet 9 pulgadas the sharper image modelo mid900sc
Jan 12, 2013 | Tablets & eReaders
Literati won't stay on unless i'm pushing the back and screen
It sounds like it was maybe dropped, or recieved some kind of physical trauma. The Lines on the screen sound like they could be from a loose electrical connection between the screen and the mother board, and that may be why you need to apply pressure to the back of the device. your best bet would be to return the device to sharper image for repair or warranty work.
Sharper Image
Customer Service number: 1-877-714-7444
Email atcustomerservice@sharperimageonline.com. Please include where the product was purchased from as well as the date that the product was purchased.
Nov 10, 2011 | Sharper Image Literati Reader 16375680042...
Tablets & eReaders Logo
965 people viewed this question
Top Nextbook Tablets & eReaders Experts
bigdawg7299
Nhat Nguyen
Level 1 Expert
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
