Question about Whirlpool LER4634J Electric Dryer
Tring to get the fan off of the motor on whirlpool dryer
I have a whirlpool ultimate care 2 dryer that the motor is going out on i have the drum out and the motor un hook but i can figure out what hold the fan on the motor shaft
  • 640 Answers
Nothing,,you should have keep motor clipped down,,and first remove blower wheel its just screwed on the front side of motor,,put motor back hold the end of motor with wrench,,than turn blower wheel..onthejob
Posted on Jan 24, 2009
  • onthethejob1
    onthethejob1 Jan 24, 2009
    nothing,,you should have keep motor clipped down,,and first remove blower wheel its just screwed on the front side of motor,,put motor back hold the end of motor with wrench,,than turn blower wheel..onthejob
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My whirlpool ultimate care II electric dryer won't
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Jul 21, 2011 | Whirlpool Dryers
    Whirlpool ultimate care ii dryer, only works when continuosly pressed the start button. What can be the problem. whirlpool ultimate care ii dryer model gew9878lw0
    More likely than not either the start/run switch on your motor wen't bad, or the motor windings itself. Either way you need to replace the motor #279827 around $100 on up.
    Not tough to get to if you know how to gain access to the cabinet, just remember that the blower wheel and motor threads going into the blower wheel are LEFT hand thread,
    have fun, and best of luck,
    ttfn
    Feb 04, 2010 | Whirlpool Dryers
    Whirlpool Ultimate Care II drum does not spin.
    Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
    Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
    If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
    Dec 21, 2008 | Whirlpool LER4634J Electric Dryer
    How do I access the drum of a Whirlpool Ultimate Care II gas dryer?
    I had to remove two screws from the brackets on the back of the dryer, and the two screws from the dryers screen. Then I pushed the pins under the top portion of the dryer with a standard screwdriver, as I pulled up on it. I was then able to access the drum area.
    Nov 16, 2008 | Whirlpool Dryers
    Whirlpool Ultimate care ii Dryer wont tumble
    If your dryer doesn't tumble, check these:
    Belt,
    Motor,
    Door switch.
    Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
    Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
    If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
    Remove the belt,
    Check for obstructions in the blower fan housing,
    Manually rotate the shaft of the motor.
    If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
    If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
    Go here to see a diagram for your model:
    one of two types. "H" or "J"
    http://www.repairclinic.com/0079.asp#DiagramH
    Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Dryer Motor Removal
    stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
    Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
    Whirlpool LER4634J Electric Dryer Logo
    159 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
