Question about Radio Communications
Installed auvio wireless headphones. now recharging new batteries for first time. blue light should be blinkingwhen charging and lights blue solid when charged. i have only red light on no blues
  • 10 Answers
SOURCE: blue wave wireless headphone
Please take out the batteries from the dongle and headset for 20 minutes.
Insert a new battery into the dongle, plug into your player and turn it on.
Wait for 2 minutes, insert another new battery into the headset and turn it on.
It will take about 2 minutes to connect each other at first time.
Posted on Jan 03, 2008
SOURCE: jabra bt160
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2)
For optimal performance, wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight. In general, you will get better performance when
there are no obstructions between your headset and your mobile phone. (See fig. 5)
Answer a call
Tap the answer/end button on your headset to answer a call
End a call
Tap the answer/end button to end an active call
Reject a call (Dependent on your phone supporting this feature)
Press the answer/end button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (subject to phone
settings) automatically transfer to your headset
Activate voice dialing (Dependent on your phone supporting this feature)
Tap the answer/end button. For best results, record the voice-dialing tag through
your headset. Please consult your phone’s user manual for more information about
using this feature
Redial last number (Dependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+ or –) to adjust the volume (See fig. 1)
5 How to...
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT160
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’
‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’
or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 4)
3 Pair it with your phone
English
2 Turn on your headset
Press the answer/end button to turn on your headset
Press and hold the answer/end button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
Posted on Jun 16, 2008
  • 5 Answers
SOURCE: why does insignia ns-bthdp have a solid blue light?
I had this problem but the red light was on constantly with no response to anything I did. I plugged this into my power adapter and pressed the + and - buttongs at the same time and it reset and started working properly.
Posted on Dec 14, 2008
SOURCE: bluetooth wont turnon new unit out of box
Pardon me if you have already tried this but with my em236c I had to hold the Answer/End button for about 15 sec before it flashed red/blue. The manual doesn't say how long to hold it. It took a couple of tries for me. Hope this helps.
Posted on Jan 12, 2009
  • 53 Answers
SOURCE: My Insignia NS-BTHDP headphones don't have a red
The LED may have just gone bad. Keep using it untill the battery dies, then try charging it and use it again. If it works as it should it means the LED died and there is nothing to worry about, if not you may need to replace the battery.
Posted on Jun 16, 2009
My Audio headset has worked great-but now...it stopped working
Could be the battery has a weak charge! Try running the battery completely flat, recharge fully, then run completely flat, and repeat this cycle about 3 times......This will give the rechargeable battery a revitalised full charge! This is a good procedure for any rechargeable battery as part charging and charging when not completely flat does take its toll on a battery.
Nov 12, 2015 | AUVIO Bluetooth Headphones
Bluetooth won't charge. Red light comes on and then turns off. Bluetooth won't work.
Sounds like the rechargeable battery in the bluetooth device has failed. (Most bluetooth devices do not have batteries that are replaceable.)
May 15, 2015 | AUVIO Bluetooth Headphones
Suddenly no sound.
yes they do, if its connect via usb cord to pc or wall wort
does no sound cause from no power light (blue light on right side) if so you might have bad batteries this has happened to me before , there not user replaceable either bummer
May 07, 2015 | Sennheiser HDR 180 Wireless Headphones
My auvio headphones show a solid red light
Charge your headphones and while they are charging press the call button and the volume up button and you problem is solved. After that just let your headphones charge.
Jun 14, 2014 | AUVIO Bluetooth Headphones
Blue light is not blinking or on at all when i set phones on charging dock.
ck that batteries are installed correctly and contacts are clean. Put the old batteries in, if it is not trying to charge them, sounds like the charger is bad.
Apr 24, 2014 | Sennheiser RS 140 Consumer Headphones
The blue light does not blink,it is a steady light that will not turn off and it wont pair up with my phone
The only way to reset your headphones is by charging them and pressing the call button and volume up and it will work like new.
Mar 26, 2014 | AUVIO Bluetooth Headphones
Red light wont turn off on auvio headset
While your headphones are charging press and hold the call button and volume up button and your problem is solved.
Mar 22, 2014 | AUVIO Bluetooth Headphones
What is a solid red light on my backbeat 903
Solid red means its charging. When its fully charged it will change to solid blue.
Aug 10, 2010 | Altec Lansing BackBeat 903 Consumer...
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
