Question about OKI ML8810 Printer
108 power oki ml8810
Code error
I got code 108 eror
How to solve 108.xx, 108.08 error on Lexmark printers ~ Fix ...
fix-your-printer.blogspot.com/.../how-to-solve-108xx-10808-error-on.ht...
How to solve 108.xx, 108.08 error on Lexmark printers. A 106.xx, 107.xx, 108.xx, or 109.xx error indicates a problem with one of the ... Libell?s : Error code ...
IBM OPOS, Common Error/Return Codes - United States
www.ibm.com/support/docview.wss?uid=pos1R1000395
IBMMar 30, 2006 - I'm new to OPOS and get error return codes or result codes. What do ...108, OPOS_E_OFFLINE, The physical device is not connected or not ...
why am i getting error code 108 - QuickBooks Learn & Support
Dec 26, 2015 | Office Equipment & Supplies
What is code 108 on realplayer sp converter for mac
Error #108 Invalid Auto Transport Configuration setup. Error 108
May 10, 2014 | Apple 24" iMac Desktop
Mithsubisi cassette unit Error code S108
Error 108 are caused by misconfigured system files.
Error 108 Problems usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
Try disconnecting power for 10 minutes or so to reset the unit.
Jan 17, 2013 | Heating & Cooling
Wii u error code 108-0170
This is the "official" nintendo explanation:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=108-0170&system=Wiiu&locale=lang
If those items do not work, I highly suggest in it being that new you request service, replacement etc. under warranty by calling their # at the bottom of that page.
Dec 22, 2012 | Nintendo Wii U
Code 173 for oki c5500
Service call 172:Error & 173:Error
Both errors mean -
Abnormal temperature detected by fuser thermistor (high-temp or low temp.)
Does error reoccur?
YES -
Turn power ON again. Replace fuser unit.
Jan 19, 2011 | OKI C5500n Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
Xerox Docucolor error 116-324
xerox phaser 6280 phaser controller error 116-324 i already powered off and on error returns i also replaced the contoller bd same problem can you help me
Apr 08, 2008 | OKI B6300n Printer
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
OKI ML8810 Printer Logo
242 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
