Question about Dell SE198WFP LCD Monitor
Wide screen not active
I have used this monitor for over a month and it has been fine. This morning it started blanking out then returning with a 3inch less screen on the right side. I have pushed a few buttons to get it back to wide screen, but it always starts flickering and returns to the blank right side of screen. What is wrong??
  • Tim101 Feb 26, 2009
    My screen has been working well for some time and today it starts getting fuzzy on the screen and then blanks out. Sometimes it comes back from the blackout fuzzy again but then returns blank.
    Sergeant:
    Champion:
  • 373 Answers
Wow maybe you should give dell a holler
Posted on Feb 10, 2009
Display was working fine. Then the screen blanked
Used monitor controls to rotate through the connection options (e.g. VGA, DVI, etc). After second pass, the monitor cleared-up.
May 04, 2009 | Dell UltraSharp 2408WFP 24" LCD Monitor
Right half of screen blanks out
Hi...there,
Well... after 3yrs of used, it's time to retired. You've got a busted panel...
Dec 01, 2008 | Philips 230W5VS (Silver) 23" LCD Monitor
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
Wide vertical lines on screen
Hello there!
First things First
1) If you can or have another monitor try and see if the problem persist.
2) RMS the monitor if you keep these problem in these particular monitor.
3) usually these, problems, its cause by a bad capacitor in the monitor motherboard, or resistor.
4) it is best to return the monitor.
Carl
Apr 25, 2017 | Gateway FPD1775W Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Acer Monitor
You're going to have to provide more info than that.
What were you doing when it happened? What are you typically doing when it happens? Have you checked your cables? Power connection?
As it stands, your inquiry will not receive much of a useful solution for you unless you let us know these things.
And don't rate me poorly for letting you know this. I'm here to help you. You have to HELP US help you.
Cyryl
Dec 10, 2007 | Acer AL1916B 19" LCD Monitor
Problem in monitor the screen doesnot get full wide of it by control panel
Assuming your running Windows as the operating system on your computer, go into Display Properties and set the refresh rate to something other than 60 hz or default. On my XP computer this can be done by right clicking on the desktop, clicking Properties -> Settings -> Advanced -> Monitor. Anything in the 70, 72, or 75 hz range should work fine. If this does not fix the problem and the monitor is out of warranty trash it and get another one.
Nov 10, 2007 | Hansol 730E 17" CRT Monitor
Blank Screen
ccfl ( cold cathode flouroscent lamp ) is the backlit feature of the lcd panel. If you see a blank screen but do see the output on the external monitor then you sure have to take it to the hardware tech to get the inbuilt LCD panel checked. it seems to be a electronic failure. Thanks Ashish.
Sep 21, 2007 | IBM 11P836402 for ThinkPad R40 Monitor
Monitor Display Problem.
Like most of these LCD monitors it is more than likely a PSU problem to do with the Electrolytic Capacitors, These in all probability will be faulty.. there are usually about 4 - 6 from 1000uF to 100uF replace ALL with same or better.
May 31, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Dell SE198WFP LCD Monitor Logo
81 people viewed this question
Alun Cox
