Question about Acer Aspire 3100-1405 Notebook
Acer 3100 boot freeze
When i press power my note book acks like its going to boot and will then freeze half way through the acer boot screen.
  • 191 Answers
Boot frozen you may try
1) change RAM memmory or change the memories slot between one and another
2) check cpu fan works when booting
3) clean the dirty stuff through the way of cpu fan
if not fix, your motherboard hardware need to repair by the specialist
Posted on Jan 24, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
The screen on my Acer Aspire won't turn on?
do one thing
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
5.if you will get the same problem again means suspected issue with main board.
Nov 18, 2010 | Acer Aspire 3100-1405 Notebook
AOA150 acer asire one won't boot up at all. Have
when the screen is black try hitting ctrl alt delete a few times and you should get some options to work with
Apr 04, 2010 | Acer Aspire 3100-1405 Notebook
Boot Acer 3100 Aspire. Shows NTLDR is missing Press any key to restart. Will just go to the same screen over and over.Will not boot at all. Do not have a boot disk.
Remove any 3.5" diskette from the A: drive.
Remove any CD from the CD/DVD drive.
Reboot.
If you still have the problem, then borrow a Windows XP disk.
Boot from it. Choose "repair", not "install".
If the disk-drive is "detected", then "repair" will attempt to fix any file-system errors.
If *NO* disk-drive is detected, your disk-drive has "died".
Nov 01, 2009 | Acer Aspire 3100-1405 Notebook
Unlock a bios password on an acer aspire
Hello, I have an old Acer Aspire 3680, the problem is once i press the power button the screen is frozen displaying only the Acer logo, i cannot even go to the BIOS (pressing F2) to change my setting to boot from a CD. Please help. THX
Jul 31, 2009 | Acer Aspire 3680 Laptop
ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
May 23, 2009 | Acer Aspire 5100 Notebook
Mouse and keyboard freeze.
its a very common hardware fault with these laptops, can you open setup or bios? that is opened right when the power is turned on the and screen says press F2 to enter bios or setup, if you can't enter bios then you have a faulty motherboard, usb ports don't work either? (usb keyboard and mouse don't work?)
May 13, 2009 | Acer Aspire 3100-1405 Notebook
My acer 3100 does not recognize internal usb
Go into device manager and Un-install them and let the computer Re-install them.
Jan 27, 2009 | Acer Aspire 3100-1405 Notebook
Will not boot up ( acer aspire with vista basic)
0xa 0000000 is a hard drive error .. either your controller or your hard drive has failed ..
Dec 28, 2008 | Acer Aspire 5315 Notebook
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
What is going on
you need to do some cleanup.
remove unwanted programs.
remove temp files
defrag hard drive
the if you still have problems you need to clean the registry
mostly hkey local mach>microsoft > windows> run
and remove unneed startup programs
also
go to start button and right click and select open all users
and ten select startup and remove programs that are not needed.
Jan 10, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 3100-1405 Notebook Logo
213 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
