Question about ASUS A8V-MX (MBA8VMX) Motherboard
ASUS M2NPV-VM Motherboard Graphics Problem
When I turn on my computer, with monitor attached, the speaker inside my case does a long and 2 short beeps. I looked and saw this is due to graphics (vga) failure. The motherboard is new right out of the box. Any help would be great!
    Problem Solver:
  • 11 Answers
Turn off the PC. Take out the RAM and the graphic card (if it's not onboard) and put them back in.
Posted on Jul 09, 2007
SOURCE:
I need asus m2npv-vm lan driver pls help me
You can download the LAN and device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jul 02, 2011 | ASUS M2NPV-VM Motherboard
I have an Asus m2npv-vm motherboard and two pcie network cards from various vendors. None of them is working under FreeBSD: should I configure pcie in BIOS some special way to get them work or is there a...
FreeBSD is pretty picky when it comes to Network cards, i have mostly had luck with the brand name Intel network adapters, or Netgear, NetLink, but i suspect its probably more of a unsupported card by the OS then anything else.
Dec 10, 2017 | ASUS M2NPV-VM Motherboard
Onboard video card not working. New card not either
please check Ram bcz its ram beep sound may be ram not attached in proper way that why sound come or may be its damaged
May 10, 2010 | ASUS M2NPV-VM Motherboard
Asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Sep 05, 2009 | ASUS P4P800-VM Motherboard
Need drivers for dis motherboard m2npv-vm for network conection
You can download the drivers for this MOBO from this link http://support.asus.com/download/download.aspx?modelname=M2NPV-VM&SLanguage=en-us
Jun 14, 2009 | ASUS MOTHERBOARD M2NPV-VM SOCKET AM2 NVI...
I dont know how many ram and video support my motherboard
This motherboard supports upto 8 GB of RAM..It already has 512 MB of Video with Nvidea graphics card which is HD compatible. I am not sure if you want to put some more onto it.
Rate the solution as Fixya !
tnx,
AD
Feb 26, 2009 | ASUS M2NPV-VM Motherboard
Latest drivers
http://www.driverstock.com/ASUS-M2NPV-VM-driver-download/6-9-10277/index.html
thie above site should have the drivers copy paste into address bar check driver suitable download
Jul 09, 2008 | ASUS M2NPV-VM Motherboard
M2npv-vm motherboard
The board is a mini-ATX board. As such the ASUS M2NPV-VM board is able to fit into any mini-ATX case or bigger.
uATX Form Factor, 9.6" x 9.6" (24.5cm x 24.5cm)
Jan 08, 2008 | ASUS M2NPV-VM Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
Open Questions:
See all ASUS A8V-MX (MBA8VMX) Motherboard Questions
ASUS A8V-MX (MBA8VMX) Motherboard Logo
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
