Question about Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
My RFG297HDRS has jack hammer sound when delivering water
Please address this problem
Samsung model RFG297HDRS manual
then you need a repairman . or a new one
Oct 22, 2015 | Samsung RFG297HDRS 29 Cu Ft Stainless...
Why is water leaking in?
If this is a freezer on top unit you may have a blockage in the drain tube that is beneath the evaporator in the freezer
Jul 17, 2015 | Samsung RFG297HDRS Stainless Steel
Locate ice maker water level control?
This should be automatic. What is the problem--too litte ice? Do you have a in line water filter out side of unit? Filter in the fridge? Check for dirty filter and you may fix the issue of not enough water getting thru.
Jul 16, 2014 | Samsung RFG297HDRS Stainless Steel
Kitchenaid Dishwasher makes jack hammer sound when filling
Check the power to the valve actuator with a meter. If the power is not fluctuation (causing the valve to open and close quickly) then the problem is likely "water hammer" in the piping leading to the DW. Water hammer occurs when a fast flow of water turns a corner in the piping. The solution is too find where the pipe is vibrating and add support. Another way to eliminate water hammer is to install a shock tube on the pipe. It is filled with air and acts as a shock absorber when the water hammers. They are available at Home Depot, Lowes, plumbing supply places, etc. Another way to make a shock absorber is to install a tee in a horizontal part of the pipe with an 18 inch+ piece of pipe installed vertically and capped at the top. Air gets trapped in the vertical pipe and cushions the vibration. You might be able to do this in the space behind the DW before the pipe connects to the DW. The shock tube is smaller and does not have to be vertical so if space is an issue that may be the way to go.
Sep 18, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Ipod Nano 4GB does not deliver sound
Try slowly and carefully twisting the head phone plug in the jack while music is playing. If it starts coming in in a choppy manner, then you may need to a) resawder the jack down or b) get a new ipod. I'd recommend b.
Mar 06, 2009 | Apple Audio Players & Recorders
Clunking noise in sink
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Jan 17, 2009 | Home
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
26 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
