Question about Frigidaire Dishwashers
I have a Frigidaire ultra quiet energy star dishwasher and the dial gets stuck halfway through the cycle. It runs all day if I'm not home. And when the dishes come out, there's bits of dirt and what looks like gritty sand stuck on all the glasses. I was going to clean the filter out but I don't know how to do that. It's a ten year old model (at least) and I have no paper information about it. Help!
localwonder
  • 6784 Answers
SOURCE: Dishwasher not cleaning the dishes
Hi there. Here are some solutions that may help you combat this issue with the non cleaning of the dishes during the wash.
• Choose another cycle for longer washing
time.
• Check rack loading section for proper
loading—avoid nesting items.
• Home water pressure may be too low—
should be 20 to 120 pounds per square inch
(psi).
• Check incoming water temperature. It
should be at least 120°F (49°C). (See
Factors Affecting Performance.)
• Check water hardness. For extremely hard
water, it may be necessary to install a water
softener. (See Detergent Chart.)
• Use fresh detergent.
• Check to make sure funnel in top rack is not
blocked.
• Make sure items are not blocking the spray
arms, preventing them from rotating.
• Check to see if the rinse aid dispenser
needs refilling.
Next, you mentioned in your text that you were experiencing a burning scent after the was or during it. i have a few solutions for that as well.
• Soiled dishes left in dishwasher too long can
create an odor. Use Rinse & Hold cycle.
• There will be a "new" smell when first
installed. This is normal.
• Check to see if unit is draining properly.
One more thing, sometimes food or plastic dishware will fall between the spaces in the basket that holds the dishes. these plastics can be burned by the heating element inducing a burning scent during the drying process. always make sure that all plastics are secure before you start the cycle. food can get stuck on this heater element as well causing a burned smell.
Posted on Feb 15, 2009
  • 677 Answers
SOURCE: Dibris on glasses afterwash. Dishes not coming clean
could be hard water in your area leaving minerals on your dishes.www.dishwasherfilter.com has an amazing product out that fixes this problem once and for all. it is a small filter that filters the hardminerals out of your water before entering the dishwasher. it is very affordable and guaranteed to work or your money back. you will be amazed how clean your dishes look.
Posted on Aug 11, 2009
  • 382 Answers
SOURCE: my diswasher is leaving a grimy film on all the
Go to you local Supermarket and purcase a bottle of disjwasher cleaner is about 8 bucks a bottle in some cases you may need to use two bottles I would buy 2 but use just one if it works save the other one for a future occasion.Follow all directions on bottle..Make sure you use it in an empty dishwasher and turn hot water tap on closest to dishawsher to make sure it is filling with hot water...You will be quite surprised at how clean your first load of dishes will look after the cleaning
Posted on Jan 23, 2010
SOURCE: Dishwasher gets stuck on heating delay for hours
i have the exact same model with the same problem, i am hoping someone give us a solution.
Posted on Jun 28, 2010
SOURCE: Frigidaire Ultra Quiet 111 - ground up dirt on dishes
Remove the bottom plate near the floor. You can then look in under the dishwasher machine. The feet are adjustable up/down with a wrench most of the time. The dishwasher machine should tilt slightly away from the over flow sensor. In this case, Frigidaire Ultra Quiet, the rear feet should be lowered, or the front feet raised. If you have a machine with the over flow sensor on the bottom, at the back, tilt your machine slightly forward. Use detergent that dissolves food proteins. Problem solved. If you care to reward me, put a small symbolic sum to paypal account carolehel@aol.com
Posted on Apr 28, 2011
My frigidaire ultra quiet III dishwasher sticks on wash cycle. whats wrong?
Good Morning friend, thanks for your inquiry!
From the information you have provided your Frigidaire dishwasher is sticking on the wash cycle. Do you mean the button is sticking? Or is it stuck on that cycle? If the button is stuck you may have an issue with your keypad and in order to help unstick the button I would push it down to see if that helps alleviate any tension.
If you dishwasher is stuck on the wash cycle I would recommend performing a reset and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to have an issue with your cycles I would suggest having a professional out to properly diagnosis and replace any electrical components. I hope this information has been helpful. -Matt
Apr 06, 2015 | Frigidaire Dishwashers
Wash cycle knob
It's a quirk of the cycle timer. You can replace the timer ($) or live with it. Besides, a replacement might have the same quirk
Jul 15, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Won't turn on. Frigidaire, precision wash, ultra quiet 1
I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
Feb 28, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Jan 21, 2010 | Frigidaire Dishwashers
Where do I find the model number on my Frigidaire Dishwasher. It is a built-in model ''Ultra Quiet I'' I do not remember how long ago I bought it and had it installed. The model number entered was picked...
It should be located on the inside perimeter of the door on a metal plate. If not there, and there is a bottom panel, try and remove it to see if they put it there. You shouldn't have to pull it out I am sure. Just look real well with a light inside and u should find it.
Good Luck,
Shastalaker7
Nov 05, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Cycle Sticks unless I manually move it along
Ya, the mechanical timer/dial is the problem. The heating element just got stuck on as the timer stalled in that dry cycle.
May 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Cycle stops, lights blink
I have the same problem, same model. Driving me nuts. Help!
Dec 03, 2007 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwashers Logo
32 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
