Error drum brother tn-650 - Office Equipment & Supplies
2 Suggested Answers
ross_lovegro
SOURCE: Brother MCF-7340 first time toner replacement
If it is your first toner replacement you shsould only need the TN-360, as the drum should be good for about 12,000 copies. The machine will tell you when you are getting close to replaceing drum unit.
Posted on Oct 13, 2010
Where is the cartridge on a brother laser printer HL-1400
I don't see a Brother HL-1400 on their site. However, there is an HL-1440 which uses the TN-430 (regular) or TN-460 (high yield) toner cartridges. This printer also takes the DR-400 drum unit.
This toner cartridge works with several models in the HL-1400 series, including the HL-1435, HL-1440, HL-1450 and HL-1470N.
I hope this helps.
Aug 25, 2016 | Brother HL Office Equipment & Supplies
Tip
How to extend the life of a TN-330 drum kit for MFC-7840W Wireless Printer
If you have received any of the following messages on your Brother MFC-7840W wireless multifunction printer while utilizing the TN-330 drum kit then you may not have to replace your drum, at least not yet.
Drum End Soon
Drum Error
Toner Life End
Toner Low
I had this issue happen to me about 150 pages ago (some text, some pictures) and I still haven't replaced my drum after I executed this little trick.
Take your drum kit out of your printer (make sure you turn off and unplug any cables first)
Take some black electrical tape and cut a inch by inch square off.
Place the black tape over the optical port as shown in the picture below.
Then put the drum back into the printer, cable everything back up and turn the power on.
Your drum should last a long time beyond what was supposed to be a low toner.
Hopes this saves you some money.
on May 19, 2010 | Brother MFC 7840W Printer
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
I bought the printer in early 2006. After the initial cartridge ran out, I went through 2 TN-570 cartridges. After that my problems started. I put in a new authentic TN-570 cartridge and got heavy...
If you are still ghosting after replacing the drum (especially multiple times), it shounds like you need to have the high-voltage power supply PCB (HVPS PCB) MSRP is $43.38
No matter how little or how much you print, mostly depending on the type of paper used and the environment, this part can go out.
Jan 31, 2010 | Brother HL 5170DN Laser Printer
Change drum
You need to go buy a Brother DR-350 drum unit cartridge. The drum unit is the thing that the toner cartridge (TN-350) clicks into. Pull out the drum/toner unit and separate the two halves. Place your TN-350 into the new DR-350 cartridge and put back in the printer.
Jan 18, 2010 | Brother IntelliFax-2820 Laser Fax
I have brother tn 350. it is saying drum error.
Depending how old the drum is, you may have to replace it.
If its new then take it back to were you bought it and tell them its faulty
Sep 29, 2009 | Brother Office Equipment & Supplies
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
DRUM ERROR
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
It happens because Brother decide that we are morons and cannot figure out when a drum is dead and so they make the printer refuse to work after a certain amount of time. This resets their dummy counter.
Jul 07, 2008 | Brother MFC-7820N Printer
k24674
