Question about Northstar Professional Series Pressure Washer 4000 PSI
Water in the hydrailic pump oil - Northstar Professional Series Pressure Washer 4000 PSI
Were can i fill up my audi's hydrailic fluid for the roof
resevoir is on pump on the right rear corner of the car. You'll have to crawl in and see, or pull the pump out (2-3 bolts) Tyr this link for more info.
Apr 29, 2014 | Car Audio & Video
Is there a weephole for oil and one for antifreeze or just one weephole for both on the water pump of 2005 ford taurus
It is very unusual for oil to run from a water pump, but you can get a leak from the grease that lubricates the bearing. If you do have what looks like oil or grease, you probably need a new pump.
May 20, 2012 | 2005 Ford Taurus
Oil and water comming out of oil filler stem
You have a seal on the pump between the pump and the water pump thats leaking you have oil and water mixing . I owen three mechines and i don't understand what you mean when you say the oil filler stem. I also rebuild power washers and pumps. If you can clarify where the water and oil mixture is comeing out then i can tell you excatly what the leak is thanks
Jan 09, 2011 | Comet BXD2527 Pressure Washer Pump
My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
Good news, your engine runs
But your pump may be bad
Here's how to test your pump
Check oil as outlined lower down
Disconnect the washer hose and gun
Connect water hose and turn on water and water should pass straight through the pump
Look for clogs in the hose-end where water hose connects to machine
Turn on machine and see if water shoots out pump
If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
Look for clogs in the end of each water connection.
Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
Finally, the gun trigger mechanism may be bad
I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
Check your pump oil
Pump oil is SAE20 or SAE30 non-detergent motor oil
Pump should be no more than 1/2 full of oil
Use plastic hose to drain pump oil
Do not turn machine on its side or turn machine over or engine oil will run into carburetor
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
2002 mustang 5 speed 6 cyl.....does it have clutch fluid and if my clutch was goin out would it make my car die when i depress it? when i start the car there is a loud squealing noise.....also there is a...
yes hydrailic and no will not affect engine. Engine problem is just more noticed when transmission not engaged.
Squealing is probably pilot bearing--not a big deal.
Tapping--maybe lifters pumping up
Engine light--get car scanned and report trouble codes back to us.
Autozone and Advance, among other parts stores, offer free scans.
Sep 17, 2010 | 2002 Ford Mustang
Milky oil on my wr450f 2004
your water pump seal and oil seal have failed on the water pump shaft. Replace both seals noting which way the seals face. replace the water pump shaft if it is scored. Chaz- Moto DC
Jan 20, 2010 | 2004 Yamaha WR 450 F
Yamaha r1 5vy how to remove the oil/water pump
Drain the oil and water. Remove the radiator and exhaust pipes. Remove the oil pan on the bottom of the engine. Remove the bolts holding the water pump/oil pump on.
Here is a diagram of the oil pump/water pump:
http://216.37.204.203/Yamaha_OEM/YamahaMC.asp?Type=13&A=493&B=9
Aug 16, 2009 | 2005 Yamaha YZF-R1
Leaking both oil and a mixture of oil and water
well when you have water and oil both leaking it most of the time means a head gasket or in your case a jug gasket
May 25, 2009 | 2004 Yamaha YZ 250
Northstar Professional Series Pressure Washer 4000 PSI Logo
20 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
