Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My computer will not recognise my scanner
I have a hewland packard printer 2520C but since my computer has been put back to default settings after having a virus it will not recognise it. Can anybody help? The printer is firing up and the plugs are all in the right places what else can I do?
    Genius:
  • 1,124 Answers
You need to install your printer again.
But First do this:
(*A)
1) Uninstall the software printer,
2) Delete all the printer folders created during the last installation.
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
If you dont have the CD to reinstall your printer, do this go to: www.hp.com
Support >> Sotware and drivers
And download from there your printer software
Posted on Jan 24, 2009
Can faulty ink cartridges prevent the printer from copying or scanning?
When you power up the printer it should go thru POST and your scanner should go thru the motions. You can lift the ADF lid and see if the light goes on while it goes thru POST. Also try resetting the printer to factory default.
May 30, 2014 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Tip
What is a Scanner Error 5 Hewlett Packard M2727nf MFP
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M2727
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
This printer is under HP Warranty until Mar 23, 2011
Contact Hewlett Packard for Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
2 parts need to be replaced at the same time
Parts Required as follows
Formatter - CC370-60001
Scanner/Flatbed - CB532-67905
Warranty Extension Expiration 2011-03-23
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
Hewlett Packard Laserjet M1522
Contact Hewlett Packard for possible Warranty repair. See Link Below
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
HP Officejet 4500
You need to make sure you have the right software installed on your computer.
Click on the link below and choose your operating system to get the right software.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3919448
Dec 09, 2011 | HEWLETT-PACKARD HP 4500 All In One Printer...
I HAVE A LEXMARK X2600 PRINTER SCANNER AND COPIER IM WANTING TO SCAN SOME PICTURES AND PUT THEM ON MY COMPUTER BUT IT ISNT ALLOWING ME TO DO THAT IT WONT SCAN THEM TO MY COMPUTER ANY SUGGESTIONS
open Photoshop software select pic scanning then settings and select default settings it would work. its becoz the pic size exceed the pic allowed in your settings.
May 13, 2011 | Lexmark X2600 InkJet Printer
When im trying to print a document using an hp laser-jet p1005 the printer doesnt respond but i get an error message one of the usb devices has malfunctionedand windows does not recognise it wha should i...
unplug the usb from the computer. try uninstalling the printer from the control panel.
then reboot the computer and plug the usb back in so that it will reinstall.
this may help. try this first.
Mar 28, 2011 | HP Hewlett Packard LaserJet P1005 Printer
I have two laptops - a Sony Vaio and a Packard Bell Easynote. The Hitachi HDD connects fine to the Sony via the USB - showing immediately in 'My Computer'. However, this is not the case with the Packard...
You might be using a lower version of OS in your packard bell computer. You will need to download and install a device driver for your hitachi HDD. Im not sure of the HDD model that you have but you can try searching the driver for the packard bell Operating system
Oct 25, 2010 | Computers & Internet
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Direct Printing
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Mar 27, 2008 | HP Scanjet 4370
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
