Question about Air Hogs Glow In Dark Havoc Stinger Rc Helicopter
Wont fly it wont move at all
On the box it should say a letter for channel a b or c and on the control their is a button that has a b and c set this to the same one on the box and the problem should be solved
Posted on Mar 19, 2009
We have a Haco press brake ATS650. The machine is operational but the blade will not move down ?
this sounds as if one of the safety switches are not being engauged correctly (, main motor runs, but arbor wont engauge piviot arm to move down , solinoids not being told to stick it's arm out to catch fly wheel ,due to safety switch not allowing it too
Feb 23, 2015 | Garden
My Firewolf F+series wont go forward when flying.
Youd tail motor in bad or the wires going to is are faulty. The flight board could be bad but thats unlikely. Good luck.
Mar 19, 2014 | Generic F163 fire wolf 4.5ch rc dual...
Wont go into gear
this happens because the clutch plate is still spinning with the fly wheel. If you have just replaced the clutch it will be because the clutch plate is in the wrong way and the hub is hitting on the fly wheel bolts. If you haven't touched the clutch so far then you will have to check that the clutch slave cylinder is moving the throw out arm or if the pivot has broken off. IF that is ok then there is a case of the fly wheel and clutch plate contaminated with oil and sticking
together or lastly the lining of the clutch plate has become un secured (broken) and jamming on the flywheel/pressure plate. I am betting on the plate in the wrong way round.
Jan 12, 2014 | 1991 Chevrolet Cavalier
Sears Garden tractor does not start, how to i test to see if it is the starter or solenoid or what?
Try turning it over with the spark plug removed. If it now turns over the starter is weak and needs to be replaced. Also check the oil level. Too much oil will will lock it up.
Apr 14, 2013 | Craftsman Lawn Tractor Operators Manual...
What does it mean when the car door wont shut?
Youre door is probably bent at the door hinges. You need to adjust the latch bar on the door jam. There will be two bolts to loose and you can move the bar in all directions. You probably need to move it down.
Jul 26, 2012 | 1995 GMC Safari
2002 maxima Overheated now car wont start
try replace the tempiture sensor if that dont work pull starter and try to move the fly wheel if it dont move then the engine if fried
Aug 07, 2011 | 2002 Nissan Maxima
I cannot get the timing marks on Crank and fly wheel alinged
to be honest it not as easy as it sounds to line them both up,,,,you may need to use a locking stud to do this,, and i have seen engines that just wont line up even to half a tooth out,,, but they run just fine anyhow, its all down to just how good the pullys were cut and marked
Feb 16, 2010 | 1994 Volkswagen Jetta
Air Hogs Glow In Dark Havoc Stinger Rc  Helicopter Logo
148 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
