Question about Samsung Digimax L50 Digital Camera
White images My Digimax L50 only take videos, when i select photo and shoot one, the result is complety white image, but if the light in the location is poor, then the image is very bright my digimax L50, was working ok, but suddenly it works only in video, when attempt to take photographies the caught image this all white, but if the light in the location is poor, the photography leaves very shining and is "interleaved" one line with data and the next line white (like a TV lines) Can you help me to fix the problem.
  • 3 more comments
  • Old Venom Jan 30, 2008
    My L50 is OK some time back but now it only gives well balanced images on 2x and above optical zoom, below this it gives brighter images and sometimes nearly white images. Is this a self fixable? Can you suggest some settings that can cure it or it's also firmware problem? Please HELP !
    Please Reply at [email protected]
  • imthisulu Feb 22, 2008
  • gerardls Feb 23, 2008
    I have the same problem ,what can I do?
  • Anonymous Aug 08, 2008
    i have exactly the same problem... i think it might be better just to go n get a new one as fixing may cost loads .. based on my previous experiences... and also, i have had another problem with this cam: when i try taking pics in even a little bit dim light, i can hardly see anything from the LCD screen, so i kinda just have to guess what i'm about to capturing !! anyone has the same problem ?
  • Anonymous Sep 07, 2008
    white images
    Genius:
  • 2,985 Answers
The place to go is the Samsung Tech Support team This is not a 'self' fixable problem# It is a firmware fault which may be fixable by Samsung Free or for a modest charge - depends on the age of the camera. I the charge is not modest then the next stop is a new camera
Posted on Jul 10, 2007
SOURCE:
Samsung L50: I get a very blurry - near white image when taking pics outside. Inside the pics look ok, a little blurry though. Movie recording works fine. Help please. Tried changing batteries, reseting...
Check if you are using Auto settings. It seems you are using Manual (M) and the exposure time is too long for outside conditions (inside there is less light).
Switch the camera to Auto and it should work fine. Please let us know how it went.
Apr 11, 2010 | Samsung Genuine Digital Camera Digimax...
How to overlay picture in D40x camera
Overlaying pictures, like almost all photo manipulations, is better done on a computer using "real" software rather than on a camera. You get much more control on a computer. However, the D40 does have a wide repertoire of photo manipulation capabilities.
In order to overlay images, you must be shooting in RAW (or RAW+JPEG). Select Image Overlay from the Retouch menu. A preview dialog will be displayed with Image 1 highlighted. Press OK to get a photo selection dialog. Use left/right to highlight the first picture in the overlay. (You can press and hold the Zoom button to see the selected photo fullscreen.) Press OK to select the image. Optimize exposure for the image by pressing up/down. Press left/right to highlight Image 2. Select the second image the same way. Press left/right to highlight the Preview column. Overlay will show you the result, allowing you to go back and change things if you wish. Save will save the overlaid photo.
The shadow in the lower portion of your camera is probably caused by the lens hood. The solution is simple: remove the lens hood whenever you're using the built-in flash.
Mar 05, 2010 | Nikon D40x Digital Camera
How to shoot in black and white?
This camera is not capable to shoot images in black and white as this is not a menu selectable feature of this camera. You can take the image in color and then download it to your computer and then using photo editing software change the image to black and white or monotone using the edit function in that photo editing program.
Apr 04, 2009 | Olympus FE-280 Digital Camera
Photo appears saturated green when set on manual setting
The image you selected for Custom WB is probably inappropriate - it may be shot somewhere else with different lighting or not enough of the image is white/grey. To do a proper Custom WB, take a picture of a white or grey card in the same lighting conditions as your subject. Go to menu, select Custom WB and choose that image. Then set your WB mode to Custom (if it's not already).
When you move to another site to take other photos, you must change your Custom WB image to another 'current' one. As the sun progresses through the day, your Custom WB will need to change as well. Auto WB will, in most conditions, be able to deal with changing light if you prefer not to keep updating your Custom WB.
Feb 22, 2009 | Canon EOS 40D Digital Camera
Fuzzy Images
There is insufficient light indoors, so the camera is selecting a slow shutter speed, which is causing camera shake, hence the 'fuzziness'.
Apr 02, 2017 | Nikon COOLPIX S7 Digital Camera
Too bright pictures
Try doing a test of the same image using different "modes" and compare the results - it may just be that you've got the wrong setting.
Jun 03, 2008 | Samsung Digimax D53 Digital Camera
Can,t download or burn photos
Most likey the images have been moved from the orginal location. Try locating them by clicking on the Start Menu...Search...Pictures, Music or Video and check off the "Pictures and Photo's" box. Let the search run and see you can find your pictures. Right click on the white space in the seadch results windows and click on View...Thumbnails if you need to view the pics.
If you hover your mouse over the image it should tell you were the image is located (such as C:\Documents and Settings\(Username)\My Documents\My Pictures\(filename).jpg)
You can then go back to Photoshop open the image by going to that directory.
Feb 21, 2008 | HP Pavilion dv1000 Notebook
Outside pictures are all white.
I've got the same problem as misred. Is there anybody who knows how to solve this problem? Is it the CCD?
Dec 27, 2006 | Samsung Digimax S800 Digital Camera
Manual white balance
Click the AF-WB button and then with the wheel in the back of the camera select either K or any of the other settings. If set to K then you must go to your Menu (click menu button on back) then go to Color temp. and select your Kelvin tempature. Hope that helps....
Sep 14, 2005 | Canon EOS-10D Digital Camera
White circles appear on the image. Why is that and what can I do?
When shooting with flash in a location where there are many suspended particles, such as in a dusty area or on a snowy day, the image may contain white circles as shown in the picture below. Why does this happen? If the flash fires when a suspended particle floats right in front of the lens, the reflection of the flash from the particle appears more intensely than that of the subject, as the particle is much closer to the lens than the subject. Therefore, the reflection of the flash turns out in the image and causes an effect such as that shown in the sample image above. The closer the lens and strobe are located, allowing suspended particles to be exposed to more light, the more frequently this effect can occur. How can I avoid this effect? Ideally, it is best to shoot in locations where there are very few suspended particles. If not, you can use following method to prevent this effect. a) Avoid using flash by lighting the area as much as possible. b) If your camera has a zoom function, shoot at a wide angle.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Samsung Digimax L50 Digital Camera Logo
302 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
