Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP-57ws500 rear projection television.
I was trying to replace the convergence IC's and cracked the D board. Does anyone know how I can fix the D board or where I might be able to buy a new one? And would you know the estimated cost if I have to buy one?
  • 1,199 Answers
Go to or and one of them should have it (I would estamate cost at around $250.00 usd
Please rate this response
Posted on Jan 24, 2009
Sony KP57W5500 with the blue convergence messed up?
do not change the board, change the convergence IC's which should be stk392-560's on the D board.
Mar 08, 2012 | Sony KP-57WS500 57" Rear Projection...
I have a KP-57WS500 57 in. Rear Projection
No,U have solderwicks?U can buy it,in any Radio Shack store.Use solder iron on top of the solderwicks to soap up the solders out ICS pins.Replaced the ICS use any kind solders just resoders ICS back to the heatsink.Tries Websites Tv repair,Tv to buy a complete convergence kit.
Mar 06, 2010 | Sony KP-57WS500 57" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Green lines developing about every 6 inches going across horizontally with slight arch on end sony projection tv KP57WS500
This is convergence out ICs failure and will be replaced for correct picture in TV.
Let me know if you can solder parts in circuit board of TV with necessary tools to provide you IC number and store address, or call local TV tech for fix if you are not comfortable with TV repair.
Oct 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
Sony Convergence
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP57WV700 Convergence problem
Problem could be low voltage from power supply as well as the amp ic for the convergence board. Need to take voltage readings from the test points on the board and compare them to the readings you should be getting from the service manual.
Jun 23, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 in.
Oh no it is less expensive to repair the printed circuit boards. You should buy only the IC,s that sony recomends you to buy. They will cost you more then a replacement IC will but they are not all alike even if they have the same numbers on them. Go to and enter your model number and look for the STK IC. Don't forget to get some heatsink compound to install on the back of the new IC's before you reinstall them.. Remember to always double or triple check your work and make sure you have no solder bridges or shorts on the board. If you need a copy of the service manual, post your e-mail addy and I will send you one thru Pando. Pando is available online at for a free download. Pando lets you send large files via e-mail and the Sony manual is large. Good Luck
Mar 17, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
