How to remove Impellor from an onga 445 pump - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
Tips to service a pump: click on Pump
Posted on Jan 15, 2013
How old is the Onga 443? Do you have a pic of it please?
Hello, Ria -
Only the manufacturer of the Onga 443 MAY be able to tell you how old your pump is. You would have to provide the serial number for the pump, in hopes the company has manufacturing records in its archives. The company archives should probably have photographs of the Onga 443.
I refer you to Pentair, the oompany which owns the Onga brand name and manufactures the pumps. See the Pentair Contact Us page to find the email address for Customer Service:
http://www.onga.com.au/contact-us/
The email addresses there seem to be for sales. I would still use the email address for the country where you reside and ask that your message be forwarded to Customer Service.
Best wishes.
Jan 21, 2018 | Plumbing
Dishwasher pump impellor comes off
see the diagram for your help
May 07, 2012 | Dishwashers
The pressure for my pool is at 5 instead of the usual 8-10. When talking to my pool repairman he suggested I make sure the impellor is not clogged or have debris obstructing it. Can you please tell me...
The impellor will be on the pump body itself, right before where the motor is mounted and attached. Generally you have to remove the pump from the motor to access the impellor. If you find the shaft of the motor then you are in the right vicinity.
Apr 17, 2011 | Pool & Spa
I have an onga model 445 pump wont work on a generator
You can try running a heavier Gage or shorter cord to the genarator. If that's been done try useing a power suppley box commeing from your gen. not a surge protector this will have battries inside it, doing this will cutt down on electrical resistance. If those don't work you will need a bigger gen. The problem is the amprage is to low, one more thing, look in to a inline a/c compasitor
Apr 21, 2010 | Plumbing
Removing pool pump impellor from motor shaft
Separate pump and motor. Remove diffuser. Remove back cover from motor. Motor shaft has either a slot for a screwdriver or a flat area for a wrench. Hold shaft and unscrew impeller.
Feb 24, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Will not drain
Check where drainhose connects to waste pipe for blockage. If OK, blockage likely to be in pump impellor.
Disconnect from power.
To access pump:
Open door and remove all bottom filters. Remove all water from inside machine. In the bottom of the sump on the left hand side, you will see a star screw- remove this screw and you can remove the cover it is holding down. Under this cover you will see the drain pump impellor (white fan blade). This impellor should turn relatively easily- check for blockages (careful for broken glass!!). It can be a bit hard to reach, but you need to get your finger right around underneath impellor to ensure nothing is stuck underneath- try flicking the impellor a few times to remove any obstruction from underneath. Once clean and free from obsruction, reassemble and test
Aug 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher makes a high pitch whine when it runs
instead of motor check out the motor impeller that can make the high pitched noise if rusted or cracked. ------------- Motor and pump assembly screw and impellor help....
One of the most common question that I get on a dishwasher repair is "how does that motor and pump impellor screw come out?"
Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of metal...you guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool ( see below ) that can be purchased to help hold the impellor still so the screw can be removed, these are only for a few models and pump assembly styles.
WLP seal tool helps center and install the pump seal
Frigidaire seal - impellor remover and install tool
Once the screw is removed, the next obstacle is the impellor can also get stuck onto the motor shaft. Many times I have to break off the old impellor. A sharp blow straight down with a hammer and flat screwdriver will often crack the plastic impellor...careful not to damage the pump body! If the motor shaft has indeed rusted, clean it up really good with sand cloth.
Apr 03, 2009 | KitchenAid Dishwashers
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
