Question about Vistablet MINI 5X8 TABLET PROSUMER GRAPHICS TABLET
Cursor darts around the screen when pen touched to VisTablet Mini
After installing the driver from VisTablets website for the VisTablet Mini, and rebooting my computer, touching the tip of the pen to the surface of the VT Mini causes the cursor to jump to where i want it to go before violently darting around that area. if i try to click, the cursor is moving and it wont click, i can hold the pen completely still and the cursor will be jumping from both sides of my screen.
  • PGspy18 Jan 16, 2013
    If it makes any difference im running windows 8 pro, but on the website they have a download for Windows 7/Windows 8 so i do not beleive this is the problem
MONOPRICE TABLET PEN NOT WORKING
update drivers from the official site.
May 08, 2012 | Computers & Internet
Vistablet
I think, all you need to do is unplug a re-plug the tablet back in or take out the battery from the pen and put it back in again! It usually helps me~
Apr 19, 2012 | Computers & Internet
My Wacom pen doesn't work. The blue light on the tablet turns green when I touch the pen to it, but the cursor doesn't move on the screen. I thought that the tip needed to be replaced, but after changing...
Does the mouse work (on the tablet)? What happens when the side buttons are pressed do they work? Try un-installing the Wacom driver (Pen Tablet Utility) and Install the latest version from www.wacom.com and see if that helps.
Mar 05, 2011 | Wacom Intuos3 Graphic Tablet
The arrow on the mouse kepts junping around ?
You are probably using a laptop with a touchpad. What is happening is that your thumbs are touching the touch-pad as you type and the cursor is jumping around. Solution: disable your touch pad. You can go to Start > Control Panel > Mouse > Touch Pad > Disable
Another solution is to go to the Dell website > Support and Drivers > download and install the Synaptics Pointing Device driver and disable your touch pad using the options in this new driver.
Oct 15, 2010 | Dell U0636 Mouse
Wacom bamboo pen doesn't work it doesn't move the cursor
Go to This website and post the same question http://forum.wacom.eu/viewtopic.php?f=9
Feb 07, 2010 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Is it possible to remove features from a tablet?
I have the bamboo fun pen also. I am currently running Windows Vista 64bit home and have the same problem. I fixed mine by going into the control options > Tablet PC Settings > Other > Go to Pen and Input Devices > Settings (Under Pen Options) Then I clicked at the top Where it states "Enable press and hold for Right-clicking". I disabled that and my pen works with no holding for the right click. I can make scratch marks all day! Hope this helps you too.
Dec 25, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Pen tool not actually drawing
I also solved the problem by installing the driver from the website. The trick was to uninstall the old driver first.
Feb 06, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Wacom bamboo problems in photoshop CS2
Yeahhh! Installing the new driver completely fixed my problem! Thanks guest!
May 09, 2008 | Computers & Internet
Vistablet MINI 5X8 TABLET PROSUMER GRAPHICS TABLET Logo
96 people viewed this question
Top Vistablet Computers & Internet Experts
David Payne
David Payne
Are you a Vistablet Computer and Internet Expert? Answer questions, earn points and help others
