D-Link AirPlus DI-524 Wireless Router
Problem for D-Link AirPlus DI-524 Wireless Router
Set up dl-523
By dopey_dean on Jul 09, 2007
just cant do it i have followed instructions and im not very computer liturate. i followed the instructions and then i says there is a problem with connection or something. is there an easy way to set these things up using xp? its taken 2days so far ha ha. some one please help me....
Best Solution
posted on Jul 09, 2007
Very Helpful)
sandrew
Rank: Wiz  D-Link Expert
Rating: 83%, 5938 votes
Assuming you have connected your DSL/ADSL modem to the Wan port at the rear and connected one pc to the router via an RJ45 network cable into one of the Lan ports at the rear as it is easier to set up using a cable; first go to your wireless or wired connection in control panel>network connections, right click on it and select properties and and look on the TCP/IP line and highlight it and click properties and make sure obtain ip address is ticked, ok it and close window.
Next get into your router by typing in your web browser 192.168.0.1, type admin as username and the password leave it blank, then click the advanced tab and in the left of the menu click WAN and select PPPOE if you are ADSL or DSL, if cable select Dynamic IP address, click apply
Next type in your username and password given to you by your ISP to enable you to connect to the net.
Next click the DHCP tab and the home tab and ensure that enable is ticked as this will automatically give your pc's an ip address, click apply and basically you should now get a connection.
Was this helpful?
Yes
No
Solution #2
Not Rated)
babb
Rank: Guru
Rating: 87%, 189 votes
This solution might take a while, you need to be more specific on exactly what you want to do with your router, what operating system are u using, what is the current IP address of your machine and where exactly are you getting that error message that there is a problem with the connection?
hope to hear back from you!!
regards,
babb
Was this helpful?
Yes
No
Popular Solutions for D-Link AirPlus DI-524 Wireless
Questions and Unsolved Problems for D-Link AirPlus DI-524 Wireless
Do you recommend D-Link AirPlus DI-524 Wireless Router?
Answer
Answer
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the... (More)
Answer
my computer is upstairs and the router works fine on this one downstairs, I cant find the disc for... (More)
Answer
my d-link router wont allow me to connect wireless to ps3
Answer
when i go through router setup it locks out my laptop. i need securitybut my own access at same... (More)
Answer
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For D-Link AirPlus DI-524 Wireless...:
Top Router Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
