Question about Goodman CKL60AR60 Air Conditioner
My Goodman Furnace model number GDH80703AXAC keeps tripping the breaker
    Genius:
  • Goodman Master
  • 1,363 Answers
Fan motor or capacitor.
Posted on Aug 14, 2015
Bat1956
  • 585 Answers
SOURCE: The circuit breaker trips every time I turn the
You need to start with a basic inspection in the outside unit. For the breaker to trip immediately like that indicates a dead short. With the breaker OFF look at the internal wiring between the contactor relay and the compressor. You are looking for signs that the insulation may have been chewed by a rodent, or a wire is off of a terminal and in contact where it shouldn't be. If the wiring looks good, terminals pass tug test etc. you may have a shorted capacitor. Make sure to check the wiring for the fan too. You can disconnect the com lead for the compressor and fan one at a time to isolate the defective component if needed. Work safe! turn the breaker on for the test, and off again before you put your hand or tools back in.
Posted on Jul 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: tripping breaker
There is a short circuit in the fan motor or compressor most likely. Disconnect the common wire to the compressor and try again. If the fan comes on and the breaker does not trip you have a bad compressor or a bad wire touching somewhere. Also,check the capacitor. Is it bulgded out or a burned wire? Could be a bad capacitor.
Posted on Aug 22, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: goodman 90+ gas furnace is tripping flame rollout
Check your vent and inducer blower for either an obstruction or water in a low spot.
Posted on Feb 09, 2010
Testimonial: "Thanks for the answer,it sounds like it definitely could be the problem with this furnace. "
jharper501
  • 139 Answers
SOURCE: I have a goodman CKJ42-1B air cond. unit. It keep
try cleani ng the unit outside with your garden hose first .sounds like its kinda dirty .the dirty er the coil is the higher the amp draw is when it is running .what size is the breaker in the box .thats a 3 an a half ton condensor
Posted on Aug 23, 2010
Raypena
  • 41 Answers
SOURCE: My goodman central air unit
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
Posted on May 30, 2011
Hi my home Elec furnace - heat pump.my hpump tripping breaker .i do replace new motor fan, defrost board and relay,new breaker .but it still tripping when furnace call heat on. So what the problems ?
You did not post the make and model number! You said you replaced the fan? The compressor and motor for the fan both use a start capacitor.
Feb 22, 2017 | Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
Goodman GDH80703AXAC pressure switch stuck open
Possible water inside switch & or tube..(Condensation)Rremove switch and gently tap the switch to see if water comes out.If not replace the switch.
Oct 29, 2011 | Goodman GMS90703BXA Heater
Furnace keeps tripping the breaker changed breaker and wires all good up to the furnace still keeps tripping when i try to turn power on. nothing happened to the furnace and the wires were tested up to the...
Disconnect the black power wire where it is connected to the furnace with breaker off. Put a wire nut on it and then turn the breaker on. If it continues to trip, the problem is not the furnace and you will have to trace the power wire back to the breaker box to find problem. Next, disconnect the black wire from the breaker (with breaker off) and then snap breaker on. If it trips, bad breaker. If the furnace was disconnected and breaker did not trip, you have a short either on the P C Board or the transformer.
Mar 31, 2011 | Heating & Cooling
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
I have outdoor Goodman compressing unit, model #cple24-1c. The breaker tripped and I was told to take out the connector located in the box by the unit and reset the breaker. The breaker did not trip again....
No, the electrical whip should be able to handle all weather, moisture, and even immersion. The only reason to replace a whip is if it has suffered some kind of physical damage. I recomend keeping an eye on it and if it trips again, have a pro come check out the system because something is not right inside the unit.
Jul 01, 2008 | Goodman Heating & Cooling
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
47 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
