Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Printing with Dlink DI-624S and VPN connection
Hi there, any help appreciated please.
I have a Dlink Di-624S DSL Modem Router. This unit has two USB ports for connecting two devices like printers, external drives etc.
With a printer connected to one of the ports, I have no problems printing from my laptop. However when I connect through the Router to a VPN, I am unable to send print requests to the printer. I have to log out of the VPN connection and then the router will pass the print request to the printer. Then I log back into the VPN to continue that work.
Is there a way that the Di-624S router can be configured to allow printing vis its USB ports when I am logged into a VPN?
Thanks in advance for any suggestions.
regards...Paul
    Scholar:
  • 93 Answers
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Posted on Apr 24, 2009
Testimonial: "Yes, thanks so much for getting back to me - albeit some time back. This solution doesn't fix the root-problem but does provide a reason to why and how I can get a solution around the problem. Thanks."
Repetitive disconnect problem....requires powering off & on to reset
I used a D-Link Di 624 for a number of years with Comcast and never had a problem with the router, but I did upgrade the firmware. You may want to look at the following items from D-Link about the DI-624S and see if you can find a better solution. I took the router out of service as I changed to Verizon FIOS and use their provided router.
See: http://www.dlink.com/support/faq/default.aspx?question=DI%20624S&page=1
Dec 06, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
How to connect DSL internet to the second computer
You need an ethernet card, either hard wired or wireless to connect your computer to the DI-624.
Jun 13, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hi i hav purchased a Dlink dir 300 router. is this router capable of letting multiple pcs n cell phones connect to it for internet wirelessly with out the need of keeping 1 pc switched on all the time? i...
Yes if you consult the manual that came with the router it will show you how to connect the modem to it and setup the DSL (PPPOE)settings. Some Modems though already have the PPPOE settings within the unit and then the router would just need to be set to automatic. You will need to configure from the PC but afterwards you can shut down all your PC's on the network at anytime.
Jun 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Please explain how to connect LinkSys D-Link wireless broadband router Model No. DI-713P with Comcast broadband modem and Dell OptiPlex 360 Desktop? I am using Windows XP-Pro. Thanks, dana
What is Comcast Modem's Model?
if your modem is not a Modem Router:
here is the link where you can download the manual...Mid left of the web page.
http://support.dlink.com/products/view.asp?productid=DI-713P
if you have Modem Router?
Bridge your Dlink router by changing the IP Address of Dlink Router and connect it wired to the LAN port.
send me your email add so that I can send the instruction How to install.
Mar 20, 2009 | D-Link DI 713p (DI-713P) Wireless Router
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dlink Broadband Router Dl-604
You can connect many computers to a network with switches, (or hubs if you want an even cheaper option) but in order to connect to the internet there will need to be a router (or modem) to connect to your ISP.
anything else?
May 09, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624s
That sucks... we need more info before we can try to help though.
Sep 09, 2007 | D-Link AirPlus Xtreme G DI-624S Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
362 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
