Question about Whirlpool MH1160XS Convection/Microwave Oven
Microwave not working properly
The hood light on the microwave blew out. When I took it out the base was stuck in the socket. I did not know if the light was on or not so I took a voltage meter and tested the socket for power. There was no indication of power. So, I stuck in a needle nose plier to remove the light bulb base. Apparently, there was power... and there was a loud pop and spark. I killed power to the microwave and changed the bulb. Now, not only does the light not work but the vent fan does not work.. however, the clock and display works. Also, when the microwave door is open the light inside comes on and I tried to put a glass of water in to see if it works and it makes a loud humming noise while the turntable moves very slowly. Is there anything I can do to make it work properly again as well as all the features?
  • rizzolee2077 Jan 24, 2009
    Does anyone else accept the theory that the circuit board was blown? Does anyone know if it would be less expensive to replace the circuit board or just to buy a new microwave?
  • 11,896 Answers
Either a fuse burnt out or a circuit board fried. That's about the only things that can go wrong with these. you will have to remove the covers to look inside to see parts. You can see if fuse is good and also see if you can smell anything burnt.
Posted on Jan 24, 2009
    Brigadier General:
  • 8,619 Answers
Hi
You can buy a new circuit board instead of microwave as I think you are smart enought to change it yourself . Click on the following link to buy a newone .
http://www.repairclinic.com/Microwave-Parts?s=a6c212
  • Rylee Smith
    Rylee Smith Jan 24, 2009
    It will cost you as low as around $50 . Before buying you can also call their toll free no. 800-269-2609
    Thanks
    Rylee
  • Rylee Smith
    Also if you want to check more before buying a new one check for all these :
    Fuse/circuit breaker
    Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
    Main wiring
    Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
    Oven wiring
    There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
    Sergeant:
  • 221 Answers
Istead of buying a board its very much advisable to get new microwave.as its the board problem in your microwave.and lso its very costly and it blows due to any of the wire getting short in the unit else where.so its quite risky to just get the board and fit it will have to checked properly before fitting the board/.
new oven is much advisable.
thanks.
    Sergeant:
  • 378 Answers
See if you say there was a pop n spark.u may hve burned up upscale connections and short tracked them.ovens are high voltage devices and i will suggest you not to try anything else on your own,call the technician to check out the damaged board and connections and replace faulty parts.till then dont even switch on the oven as it may cause more damage the more you try to use it in this situation.thanks.
  • 916 Answers
I'm sorry but this microwave will need to be repaired when you heard the popping sound there was a voltage spike to the power. Once this happened it in turn burnt out the circuit board behind the panel where the bulb and vent are.
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
The hood light blew and I replaced it. It worked
The cause could be anything from defective bulbs(least likely, to a bad bulb socket or vibration during operation. A voltage measurment at the bulb will tell you if it is getting too much.
Eric
Dec 24, 2009 | Microwave Ovens
Stuck light bulb in micro wave hood.
Be sure the oven is unplugged from the wall first.
In many cases, you have to break out the glass from the bulb and then use small needlenose pliers to unscrew the bulb base.
Once you get the lamps replaced, if they won't turn on or turn off, then you also have a damaged circuit board, which we regularly repair nationwide for $39.95 postpaid.
Details are at our site, linked is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 08, 2008 | Whirlpool MH7135XE Microwave Oven
Replacing light bulb
Remove the screws on the bottom of the unit and the panel drops. You can then remove one screw on the actual bulb holder and use plyers to spin it out. Make sure you disconnect the power.
Dec 16, 2007 | Microwave Ovens
Light socket is dead on my Maytag
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 01, 2007 | Maytag MMV4205 Microwave Oven
Surface lights
I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1160XS Convection/Microwave Oven Logo
51 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
